Activity › Forums › Apple Final Cut Pro › FCPX XML Import
FCPX XML Import
Posted by Joe Lloyd on October 24, 2012 at 8:48 pmHi All,
I have a timeline sequence that was worked up in Adobe Premiere CS6. We’re moving a bunch of stuff over and I want to bring that project into FCPX.
I’ve exported an XML and used 7toX to convert the file to an FCPXML. Once I import into FCPX, I see all the media in place. Yet no timeline at all that was present in the CS6 project. Is there a step that I’m missing?
Jeremy Garchow replied 13 years, 11 months ago 3 Members · 7 Replies -
Jeremy Garchow
October 24, 2012 at 9:14 pm7toX loads everything in to the Event.
You should see a keyword collection called “FCP7 sequences” which will have a compound clip for every sequence.
You then make a new Project and copy/paste that to the new Project.
Jeremy
Joe Lloyd
October 24, 2012 at 10:03 pmOdd. Not there at all. It has crashed on import the last time. Maybe something went wrong. I’ll redo it, and hope for the best
Andreas Kiel
October 24, 2012 at 11:29 pmJoe,
You should realize that PPro has integrated the old FCP XMEML interpretation in the app (more or less) and since it works (more or less) like FCP it’s somehow “easy”.
Phillip’s 7toX needs to convert from one kind of system to a totally different kind of system using the FCPXML “language”. 7ToX has a global approach to do the very best to translate (and it does well) but finally not every “sentence” can be translated from one language to the other.
So give it a try by eliminating tracks or filters and rebuild the things in FCPX.Andreas
Spherico
https://www.spherico.com/filmtools -
Jeremy Garchow
October 25, 2012 at 3:30 amI just did a test of a Pr Cs6 XML export, passed through 7toX.
There was still a keyword collection called “FCP7 sequences”.
Jeremy
Joe Lloyd
October 25, 2012 at 4:15 amThanks for checking. Mine is crashing on the FCPX import. Once I reload the event is there, but no keyword. So I’m assuming something in the CS6 project is bothering it.
I’ll look at quickly finishing the sequence in CS6 then start fresh on FCPX possibly.
Jeremy Garchow
October 25, 2012 at 4:32 am[Joe Lloyd] “I’ll look at quickly finishing the sequence in CS6 then start fresh on FCPX possibly.”
Or follow the advice of Andreas and simplify the Pr project before exporting.
Pr also handles a lot of formats differently than FCPX, so if your’e using any native MXF/AVCHD/P2 etc, it might be what is crashing FCPX.
