After installing El Capitan, voice over starting recording with the pitch slightly up, random echo, and random instances of static. I’m running 10.2.2.
Using H4n as a usb pass through for a Rode NT1-A.
The time readout has also gone batty. As you can see the attached image.
I am having the same problem – were you able to change the MIDI setting for the Zoom (I’m not having luck doing that) or did you adjust setting inside FCPX? Thanks for any advice!
