Activity › Forums › Apple Final Cut Pro › FCPX uploading to Vimeo keeps failing!
  • FCPX uploading to Vimeo keeps failing!
    Posted by Jenn Lindsay on May 15, 2015 at 9:00 am
    Hello!
    I’m doing the same thing I always do–going from the share menu, clicking the Vimeo icon. I have 1TB on my hard drive and just deleted half the content in my Vimeo-Plus account so there’s plenty of storage room. But the Vimeo share keeps failing: “Publishing to Vimeo Failed because file Interdisciplinary Research rough cut – HD 720p.mov is too large.” But I haven’t changed any of the pre-settings that I always use, and the video itself is only 548MB. Much smaller than I usually do.
    Any ideas? Thank you!
    Jenn
    http://www.JennLindsay.com
    iMac 27-inch, 3.5 GHz Intel Core i7. 4GB GPU.
    FCPX
    Claude Lyneis replied 11 years, 4 months ago 4 Members · 3 Replies
  • Noah Kadner
    May 15, 2015 at 9:53 pm
    I’d suggest exporting to Apple Devices and manually uploading to Vimeo and see what happens. Sounds more like an issue on the Vimeo end than FCPX.
    Noah
    FCPWORKS – FCPX Workflow
    Call Box Training
  • James Ewart
    May 16, 2015 at 11:27 am
    I’ve never liked uploading direct to Vimeo from FCPX. It always seems to take a long time. I usually use the Broadband High default setting in Compressor (960 x 540). I prefer the saner file sizes I get in return. By the time Vimeo has finished ‘processing’ the file (I’ve always assumed that meant compressing) I do not notice much difference (if any) in quality compared with HD 720P.
  • Claude Lyneis
    May 16, 2015 at 6:22 pm
    I go through compressor and use 720 p H.264 at 5000 kbits/sec then upload to vimeo. Looks good and works every time.
