  • Posted by Eric Santiago on September 24, 2020 at 6:33 pm
    I cant copy and paste the link, but here are some of the updates:
    – Fixes an issue in which XAVC media from the Sony PXW-FX9 camera is not recognized
    – Fixes an issue where brightness levels shift when switching between Better Quality and Better Performance in the viewer
    – Fixes an issue in which effect keyframes are not added correctly when using onscreen controls
    – Improves stability when using the transform tool with multiple clips in the timeline
    – Improves reliability when exporting an FCPXML that contains Compound clips
    – Addresses an issue which could prevent sharing at certain resolutions
    – Fixes an issue in which sharing a Compound or Multicam clip from the timeline was disabled
    Oliver Peters replied 6 years ago 3 Members · 6 Replies
  • Jeremy Garchow
    September 24, 2020 at 6:38 pm
    Woot!
  • Jeremy Garchow
    September 24, 2020 at 6:39 pm
    Here’s the link: https://support.apple.com/en-us/HT201237
    There’s also a Pro Video Format Update to go along with it (which probably fixes the codec issues).
  • Oliver Peters
    September 25, 2020 at 12:01 am
    I’ve lost the ability to work with RED files on the home machine with 10.4.10. Anyone else see this? I have the latest RED Apple workflow software installed, but that was from August. So maybe the update or ProApps codec update broke that again.
    EDIT: Disregard. I forgot I had this issue before on this machine. It has an Nvidia card and I’m pretty sure that’s the issue.
  • Oliver Peters
    September 25, 2020 at 12:59 pm
    Just to confirm that RED files are fine on the office machines. These are newer iMacs and iMac Pros, which don’t have Nvidia cards.
    – Oliver
  • Eric Santiago
    September 25, 2020 at 1:02 pm
    Oilver when you say lost the ability, do you mean the files come up as empty?
    I heard this from a client and always careful about how to reply or help.
    They tell you things like, “I didn’t upgrade or do anything to my computer…” which most of the time is a lie.
    That’s when I hear “Its a trap!” Stuck Out Tongue Closed Eyes
  • Oliver Peters
    September 25, 2020 at 7:08 pm
    The RED files show up as if audio-only, but basically empty. Blue, not red, like media offline. This has only happened with my mid-2014 MBP, which was one of the last ones with in internal Nvidia card.
    My guess is that it has to do with how RED is implementing Metal acceleration, which is part of the August RED Apple Workflow installer that you also have to install to use RED files with 10.4.9 and higher. So yes, it changed with the update to 10.4.9, but probably related to card support with this RED plug-in. All other recent AMD GPUs *should* be fine.
    Apple is aware of the issue.
    If your client did the 10.4.9 (or now 10.4.10) update and didn’t install the RED update as well, then he won’t see any RED files regardless of the GPU inside of FCPX.
