Activity Forums Apple Final Cut Pro FCPX transitions changes color temperature midway
  • FCPX transitions changes color temperature midway
    Posted by Elliot Lim on May 25, 2016 at 9:47 pm
    Hi there
    Noticing that final cut transitions (fade to color and crossfade) are causing a shift in color temperature in the clips either midway or just as it starts. The image moves from a cool grade to a undesired warm grade.
    Footage is from Sony Fs7, effects are default color correction and cold aura. Aggravating factor is that the clip also displays this behaviour even when the transition is moved as if it is hard coded into the footage itself.
    Has anyone encountered this before? And what was your solution to it?
    Elliot Lim replied 10 years, 3 months ago 3 Members · 5 Replies
