FCPX to PluralEyes: Import failure! Found both audio and video clips in a single lane
Dear fellow CreativeCowers!
I’m very sorry to bother you, but after looking around a while I couldn’t find a solution to the following problem:I’m editing a film, two cameras and a zoom H6:
– 25fps 1080i
– 50fps 1080p
– Zoom H6 with built in stereo mic and extra micAfter making a project, editing in the timeline, I exported the XML files, started PE, opened new project from FCPX.
Then I get the following message: Import failed: Found both audio and video clips in a single lane.Is there anyone out there who had/has the same problem, or who knows the solution?
Or do I have a bad workflow? I tried to synchronize everything first, but then PluralEyes was angry with me because I had two different frame rates.
Thanks sincerely,
xxxSusan
