Activity › Forums › Creative Community Conversations › FCPX Slow Rendering (Project Export)
  • Jeremy Garchow
    August 10, 2011 at 5:04 pm
    What is your codec of the clips and is the timeline rendered before exporting?
  • Greg Summers
    August 10, 2011 at 5:40 pm
    I use a number of cameras but in this case the entire podcast was shot with the HDV camera…..1080i 1440×1080 29.97. Most of the other shows use a combination of the iPhone 4 720P footage and the HDV camera. Just don’t remember it taking so long to render with the mixed footage. The timeline is already rendered.
  • John Pale
    August 10, 2011 at 7:29 pm
    What codec are you exporting to?
    Also, what method are you using to export? Some methods will ignore your render files (from the timeline directly to Compressor) and re-render directly to your target codec, which can take much longer, but result in a cleaner encode.
