Activity Forums Apple Final Cut Pro FCPX Replace corrupted frames using Motion. Why is the new clips shorter?
  • FCPX Replace corrupted frames using Motion. Why is the new clips shorter?
    Posted by Paul Van nierop on November 15, 2012 at 12:13 pm
    Hi all,
    I had very helpful reply on my previous post re FCPX creating corrupted frames. I found a way to replace any corrupted frames. See my previous post for details (FCPX creating corrupted frames?)
    A new question emerged from replacement of the corrupted frames, I am hopeful, that somebody might fill me in.
    I exported a selection of the FCPX clip as an Image sequence, imported the sequence into Motion, did some repair on one frame and shared it into a Quicktime movie, which I re-imported into FCPX. So far no problem. Then, if I want to replace the old (corrupted) selection for the new one, I find, that the new selection is shorter that the old one.
    I wonder why. Is a clip from images, registered more efficiently in FCPX? Or is there any other cause? I would very much like to understand more of it. Just curiosity.
    Meanwhile, I think I can solve this new issue by slightly applying a slow motion to the new selection ultil the two match again, it’s only a few frames. This will create double or retimed frames to fill the gap. But it struck me as strange. Does anyone understand and be willing to share his knowledge?
    Paul Van nierop replied 13 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
