Activity Forums Apple Final Cut Pro FCPx quits unexpectedly in one particular project
  • FCPx quits unexpectedly in one particular project
    Posted by Russ Carlin on August 17, 2016 at 1:41 pm
    Hi all,
    I’ve looked all over the internet for an answer to this. Im on an edit at the moment, about 15 minutes in and every time i try to drop a piece of footage in the timeline, it just closes. No umbrella, just closes and gives me a message saying that it has quite unexpectedly.
    I can’t figure out why it has just started doing this. It has never happened before.
    It actually appears that it is only happening in one project that i’m using, i tried opening another and it seems fine.
    What do you suggest?
    Russ
    Russ Carlin replied 10 years ago 2 Members · 3 Replies
  • Jeff Kirkland
    August 17, 2016 at 10:50 pm
    You might try deleting all the render and cache files and/or copying everything except the render and cache files to a new library.
    (For some reason I can\’t edit my own posts so apologies in advance for the stupid mistakes and bad English that I can\’t go back and fix)
    Jeff Kirkland | Video Producer & Cinematographer
    Melbourne, Australia | Twitter: @jeffkirkland
  • Russ Carlin
    August 17, 2016 at 11:48 pm
    Ok I will try this and update you. Is this safe? Spent a lot of time on it and don’t want to lose it…. if I have to start again then so be it.
    I had started with a 10 minute highlight clip that I had previously started and been added. Stuff to it and this is where the trouble started!
  • Russ Carlin
    September 1, 2016 at 11:22 am
    It actually just seemed to sort itself out. I didn’t drop any clips in to the area that i was trying to… i worked on another area for a while and then when i went back to it, it was fine.
    Very odd!
