Activity › Forums › Creative Community Conversations › FCPX Projects and Events disappear as fcpx opens
Posted by Dan Rayner on November 21, 2013 at 7:54 amHi
I am working on a project in FCPX with footage from several cameras.
Firstly I noticed that footage is not always imported when I tell FCPX to import it if I use the SD slot on the back of my iMac instead of importing from the camera.
Before this problem I trashed a cf card from a card reader and that caused fcpx to hang.
Now, when I open fcpx (I use event manager x to select projects/events), I can see me selected projects as the pinwheel turns, then they all disappear as FCPX loads. The pinwheel disappears and then the events also disappear.
Please help!Thank you
Tom Hudgins replied 12 years, 9 months ago 9 Members · 32 Replies -
Steve Connor
November 21, 2013 at 8:17 amSounds like you might have a camera folder on the root of the hard drive that your FCPX Projects and events are on.
If you have a camera folder located on the root of any hard drive, FCPX sees that drive as a camera and not a hard drive.
Steve Connor
There’s nothing we can’t argue about on the FCPX COW Forum
Dan Rayner
November 21, 2013 at 8:34 amHi and thanks
I’ve read about some issues around this but it’s not really clear to me. Though my project and event are definitely on an external hard drive rather than on a camera card.
Other projects are loading ok.
I had not shut down the computer until this problem occurred and now it all disappears as the project and events load.
The dialogue box says ‘updating project xxx’ then it all disappears and gives the option to create a new project/event.
Really don’t want to start this from scratch.
Thanks again. -
Steve Connor
November 21, 2013 at 9:03 am[Dan Rayner] “Other projects are loading ok. “
Do you mean other projects on the same hard drive?
Steve Connor
Steve Connor
November 21, 2013 at 9:18 amDid you copy any folders from the SD cards to the root of the hard drive you are having problems with?
Steve Connor
Dan Rayner
November 21, 2013 at 10:42 amWOW! I didn’t copy an entire SD to the external drive but I backed up my avchd footage by dragging it to the external drive.
I have now trashed the avchd backup file and everything has loaded! BIG relief.
Many thanks for your help. Very much appreciated.
Dan -
Steve Connor
November 21, 2013 at 10:47 amIt’s one of the most common issues that comes up, you just need to make sure that all camera rushes folders are not on the root of the drive.
Steve Connor
Steve Connor
November 21, 2013 at 11:45 am[Andy Branner] “Which is why there is a CREATE ARCHIVE BUTTON in the import window which one should use, then things like this can’t crop up.”
Does anyone know if this process verifies the data that is copied?
Steve Connor
Steve Connor
November 21, 2013 at 11:50 amNo, but that’s not relevant to my question, I’m trying to find out if the archive command is BETTER than the finder
Steve Connor
Steve Connor
November 21, 2013 at 11:57 am[Andy Branner] “Therefore even if it doesn’t, it’s still clearly the best route to take.”
Might be better than the finder but it certainly isn’t a better route than a fully verified backup!
Steve Connor
