Activity Forums Creative Community Conversations FCPX project gone!?
  • FCPX project gone!?
    Posted by Joe Mordecai on May 6, 2013 at 2:31 pm
    Hey all –
    Please direct me to elsewhere if this issue has been posted before, but I’ve just had a little heart attack moment.
    I’ve been working on an edit with FCPX, using the 10.0.8 Trial Version with a client to see if it’s a viable way forward. I was up very late working on a project. Namely, had a lot of clips trimmed and arranged into the timeline. Closed the program as normal and went to bed. I woke up this morning, opened the project, and everything is GONE in the timeline.
    All of my event info, in/out ranges, data is still there, but my timeline is empty. It’s like it erased the whole thing. Now I have to start over?? Other past projects are still fine… but this one…magically gone.
    Very upset… anyone have this happen?
    Bill Davis replied 13 years, 4 months ago 4 Members · 6 Replies
  • Bret Williams
    May 6, 2013 at 3:02 pm
    Does the project not exist or are all the edits within the project gone? If the latter… Undo undo undo
  • Joe Mordecai
    May 6, 2013 at 3:10 pm
    The project exists, but the timeline where all my cuts were was totally empty. Are there an infinite amount of Undo’s? I’ve already started rebuilding what I had done yesterday… but is that “undo” method viable?
  • Russ Haskell
    May 6, 2013 at 3:40 pm
    It’s possible the backup file is still intact (if it hasn’t been over-written this AM). With FCP closed, in the Finder, navigate to your project folder >Backups and move the backup to the same folder level as CurrentVersion.fcpproject. Hide the old one in a temp folder. Launch FCP and see whether your sequence returns.
    Russ
  • Russ Haskell
    May 6, 2013 at 4:01 pm
    Forgot to add that the backup file, which has a timestamp as its file name, needs to be re-named to CurrentVersion.fcpproject,
    Sorry about the missing step.
    Russ
  • Joe Mordecai
    May 6, 2013 at 6:57 pm
    Thanks for the advice, Russ. I manually rebuilt my timeline… but if this happens again… I’ll keep this in mind!
  • Bill Davis
    May 7, 2013 at 12:30 am
    Sorry to come to this late – and it’s probably not the issue,
    BUT.
    I sometimes see people hitting “new Compound” and not putting anything in them. If you were to do that and launch it, you can get what looks like a blank timeline replacing your populated one.
    Did you check the upper left area right below the Favorite/Reject keyword HUD to see if your timeline history was still set to your main edit?
    Just a possibility.
    Know someone who teaches video editing in elementary school, high school or college? Tell them to check out http://www.StartEditingNow.com – video editing curriculum complete with licensed practice content.
