Activity Forums Apple Final Cut Pro FCPX music trimming snafu
  • FCPX music trimming snafu
    Posted by Ben Hopkins on May 22, 2012 at 10:15 pm
    Brand new to FCPX, but a veteran to the original, and fresh off a 40 video series from Steve Martin of Ripple Training, so I feel pretty comfortable. However, can’t seem to figure this one out.
    I start out a storyline with 5 songs of audio. Then I slice sections and remove the middles. Next step is to fine tune trim the edit points, however, when I add head frames back to the A side of the edit, those frames are muted and the waveform for those frames is closed in with a blue rectangular box. Likewise, when I trim out the tail frames of the A side, the clip moves, but I can still sort of see the waveform beneath the B side, as though it is behind it. The result is that the audio from A and B are still overlapping and playing together, even though I trimmed them out. What’s going on here?
    Ben
    Ben Hopkins replied 14 years, 4 months ago 3 Members · 4 Replies
  • Andy Neil
    May 23, 2012 at 10:29 pm
    I’m not seeing your pic. Not sure if you linked it wrong, or a problem with my browser. Can you check?
    Andy
    https://www.timesavertutorials.com
  • Ben Hopkins
    May 24, 2012 at 6:02 pm
    Hmm. I tried to follow the embedded image tutorial on CC correctly. Let me try again.
    Ah, there it is.
    So, I can’t seem to get this to happen again. I started with a fresh storyline, and tried to do the same steps, but I never again saw this blue are of muted music. Everything worked fine. But should I stumble across this again, I’d sure like to know what it is.
    Ben Hopkins
  • Nik Kuo
    May 25, 2012 at 6:28 pm
    I’ve run into this exact same problem. The only way I’ve been able to get around it is to delete the music and relay it from the event browser. It’s gotta be a bug right?
  • Ben Hopkins
    May 25, 2012 at 7:55 pm
    Well, it would be just like me to run into a bug on a maiden voyage for software, one that makes me feel like I don’t know what I’m doing. 🙂
