Activity Forums Creative Community Conversations FCPX metadata–how significant is it? And why?
  • FCPX metadata–how significant is it? And why?
    Posted by Chris Harlan on November 16, 2011 at 1:18 am
    “Metadata” seems to be one of the primary answers to the question “How is FCP X more sophisticated or advanced than it predecessor?” But what does that mean? FCP7 has a pretty robust search feature, and there is certainly a huge amount of metadata available for viewing in the bins, all of automatically indexed for search. I understand that FCPX logs a lot more camera data now, which is of course a step forward. But is it any more than that?
    Other than camera info dumps–which, I agree, are quite useful–what does metadata in FCPX do that FCP7 does not?
    Bill Davis replied 14 years, 10 months ago 15 Members · 123 Replies
  • 123 Replies
  • Bill Davis
    November 16, 2011 at 3:30 am
    Here’s a small example.
    I recorded a VO. As is typical, there were good takes and bad. In legacy, that meant that I had to put the whole thing on the timeline and edit the whole down via an initial edit.
    The result was a group of individual clips laid out in time with only what I wanted (a typical timeline edit.)
    If I were to delete any of those clips – the data about their trimming and duration disappears with them since the timing data is related only to the TIMELINE. Back in the browser, the original source clip has no idea that I’ve decided (even if only temporarily) that I’m only interested in a small part of the larger clip.
    So compare that process with what happens in X.
    In the Event browser, I skim and JKL my way to setting in and out points to define each “good” snippet of my master clip. After setting the edit points, I mark each one with a single keystroke (F) to make them (temporarily) a Favorite. That preserves the SELECTION data in a persistent form in a table that I can access as long as I need it. It’s like a virtual snapshot of all my edit decisions. That decision info is PRESERVED by the NLE as metadata.
    When I do this, the original clip shows my decisions by putting a green bar on that part of the clip INSIDE the Event Browser, which gives me visual feedback on what part of my overall clip I’ve selected, how many sub-selections I’ve made in in the master clip, etc. That green bar, by the way, is something you can click on as one way among others to “recapture” the selection decision should I want to alter or amend it later, so it’s a useful tool in itself. This also demonstrates that the current data about EACH selection tag is clearly flowing between the browser and the timeline dynamically – in ways impossible in Legacy. (a color tag, for example, set in the timeline didn’t EVER reflect back to it’s source in the Browser.)
    My next step would be to open the disclosure triangle for the clip in the event browser, where I’m presented with a nice table showing all my tagged “favorites” for that particular VO clip. This shows the metadata my “selections” have generated. It’s an editable table kinda like an excel spreadsheet, and like one I can sort, or arrange clips into new orders if I choose. If I select all or any of those tags with the traditional “command click” on multiple selections, and drag the group into the timeline — BINGO, those clips arrive in the new “timeline” container as an already completed rough edit in a single step. One that reflects all the choices I made earlier ready for refinement or trimming as needed.
    Still I understand that this in itself is not that different than what you can do, (albeit with more physical “cut and edit” trimming) in Legacy.
    But in legacy, this is about ALL you can do with a clip in terms of using it’s metadata in useful ways. In X, it’s just where it begins. Because now that my “selects” are defined in the database, I can not only sort or search or manipulate that data on the CLIP level, I can work with it on a GROUP of clips. I can tag groupings of clips just like clips. (Clip Collections) Something simply not possible in Legacy.
    In X, even if I make a bad mistake and delete or screw up my timeline, my original “selects” (however I’ve re-named them as clips or groups subsequently) are preserved in the Event Browser. So it’s a nice hedge against deleting a timeline clip accidentally. Your decisions at the clip level PERSIST in X.
    On the Legacy timeline, ALL I could do was move those clips around, or cut and paste them into new timelines. I couldn’t sort them, or label them in groups, or manipulate them in any but the most rudimentary ways. And outside of saving “versions” of the timeline, none of the position information about scene edit decisions would STICK in the legacy timeline.
    In X, just like in any database, once you tag something into a particular “class” that’s just the start. We’re used to databases where “first name” might be a field, but that field can be used to display that data as part of a a name tag, an address label, or as the salutation on a letter – whatever else you want the NAME field to apply to – you just hook it up. In X, that’s just the same with clips. Once you define a clip with a “TAG” you can use it in conjunction with other tags to reorder and re-use the tagged clips to your hearts content. You can apply additional tags to already tagged clips to assemble them in sub-classes, append some or all with additional sort criteria, and search those tags all day long. If you can FIND them by tag, you can USE them by tagged groups. So the essential difference is that decisions you make in X can be made persistent and those decisions can be combined with other decisions in new ways. Also, like with all databases, your tags are so flexible they can come and go as you like!
    So after I use the “Favorite” tag to define some group of VO clips as in my example above, I can apply a NEW tag to the arrangement, Delete the Original “Favorites” Tag from the set, and now use “Favorite” tag to define the some OTHER criteria I want to use later.
    In legacy a clip would have a name set at the Capture Scratch level, but that and the master clip meta-data and and perhaps a color tag while it lived in the timeline was all that Legacy was set up to store and keep track of. Metadata is a whole different ballgame in X.
    In short, in X, clips can be appended with an unlimited array of tags, those tags can be manually or automatically generated through user actions (dropping clips into a smart collection automatically applies that collections tags to all the dropped clips) and so forth.
    Does that help outline some (among many) of the differences?
    Sorry for running on, but it’s a complicated topic and this really just scratches the surface.
    Hope it helps.
    “Before speaking out ask yourself whether your words are true, whether they are respectful and whether they are needed in our civil discussions.”-Justice O’Connor
  • David Lawrence
    November 16, 2011 at 4:36 am
    Great post Bill and really interesting. I just don’t see what it has to do with editing. Seems like a really different set of tasks than what I normally do.
    _______________________
    David Lawrence
    art~media~design~research
    propaganda.com
    publicmattersgroup.com
    facebook.com/dlawrence
    twitter.com/dhl
  • Bill Davis
    November 16, 2011 at 5:32 am
    David,
    It IS different. That’s part of the gestalt of FCP-X now. I’m operating a video editing software that lives next door to a database and each is directly linked to the other.
    I can edit without interacting with the database much at ALL if I choose. And believe me with the changes to X, it’s been tempting to concentrate exclusively on EDITING operation to the exclusion of all else!
    But I keep seeing flashes of how the database underpinnings can HELP me – if I just keep pushing myself to learn to value operating the database equally with operating my timeline.
    Simple as that.
  • David Lawrence
    November 16, 2011 at 6:32 am
    Sounds good. I’ll be curious to hear more about what you discover so please share any insights. I actually like the database aspects of FCPX, it’s the timeline that doesn’t work for me.
    David Lawrence
    propaganda.com
    twitter.com/dhl
  • Chris Harlan
    November 16, 2011 at 10:37 am
    Bill, maybe I don’t understand everything you are saying, but I’m having trouble picturing anything you are listing here as being more difficult in FCP 7. When I have a little more time I’ll try to detail this, but I’m not understanding why you seem to think it is such a hassle to use a timeline as a source bin, or why you can’t convert the contents of a timeline into its own bin, or why you can’t use bins like groups, and why you can’t use keywords and the search function in FCP7 on both clips and bins to do the kind of sorting you are talking about. Sure. It is a different approach, which some folks might really enjoy, but I am just not visualizing your description as an improvement. Only different. And in some cases with more keystrokes.
    I certainly owe you more, though. You wrote a fine description of your process, and I owe it to both of us to go line by line, so you have every opportunity to show me the errors of my thinking. I apologize for not doing that now, but the hour is late. Perhaps in the next day or two I can give you a proper response.
  • Oliver Peters
    November 16, 2011 at 1:33 pm
    One critical piece of metadata FCP X does not seem to log or at least display is reel ID. Embedded QT source IDs, like a reel number in an Alexa file do not show up. I’m sure some people and maybe Apple, too, will argue that file-based media doesn’t need that, but in fact, reel IDs are proving incredibly necessary in this modern world, too.
    Oliver
    Orlando, FL
    http://www.oliverpeters.com
  • Tony West
    November 16, 2011 at 1:37 pm
    Chris, were you able to use a keyword search window in 7?
    I went from 6 to X and in 6 there was no window for that.
    I thought the search window was new with X
  • Oliver Peters
    November 16, 2011 at 1:39 pm
    Bill,
    I’m not sure how your description of working with VO favorites is any different than sub-clipping in FCP legacy. Also if you use markers on the master clips instead of comping takes on a timeline, there’s no real advantage that I can see.
    Oliver
    Orlando, FL
  • Oliver Peters
    November 16, 2011 at 1:41 pm
    [tony west] “I thought the search window was new with X”
    Previous versions of FCP had a Find function that worked contextually in the browser and the timeline.
    Oliver
    Orlando, FL
  • Walter Soyka
    November 16, 2011 at 1:48 pm
    [Oliver Peters] “One critical piece of metadata FCP X does not seem to log or at least display is reel ID. Embedded QT source IDs, like a reel number in an Alexa file do not show up. I’m sure some people and maybe Apple, too, will argue that file-based media doesn’t need that, but in fact, reel IDs are proving incredibly necessary in this modern world, too.”
    Oliver, do you have any idea how FCPX would handle other in-camera metadata — specifically lens information that would be critical to VFX further down the pipeline?
    Walter Soyka
Page 1 of 13
