Activity › Forums › Apple Final Cut Pro › FCPX Flow transition is killing me
Posted by Larry Watts on November 18, 2017 at 5:54 pmAbout three months ago I needed to use flow. I watched Simon demonstrate MFVX’s tool and was impressed so I tried the one in FCPX. EVERYTIME I try to use it I got a beach ball. I chalked it up to my slow RAID.
Now I’m on a brand new Tech 24TB 8 drive RAID and it just happened again!
Anyone else having trouble with this?
THX
Larry
Sebastian Leitner replied 7 years, 7 months ago 7 Members · 13 Replies -
Jeremy Garchow
November 18, 2017 at 6:35 pmIt’s usually a very fast process
What kind of machine do you have? Have you contacted mvfx about it?
Noah Kadner
November 18, 2017 at 11:44 pmOn what sort of footage- codec/resolution/length. Takes about 4 seconds on my stock MBP.
Noah
FCPWORKS – FCPX Workflow
FCP Exchange – FCPX Workshops
XinTwo – FCPX Training -
Larry Watts
November 19, 2017 at 12:37 amI was on a 2014 i7 iMac pro then moved to a 2013 Mac Pro 6 core 16 gb ram. Files are Pre res 422.
this is the flow that comes with FCPX. I will buy Simons on Monday, but I cannot figure out why this would be an issue.
THX
Noah Kadner
November 19, 2017 at 3:25 amAre the clips longer than an hour? What version of OSX & FCPX are you running?
Noah
Larry Watts
November 19, 2017 at 5:10 pmClues: The timeline is HD 1080 29.97 ,the clips in questions are full 4K 23.97 RED footage. I think I must be hitting a memory ceiling. Only 16GB on the mac pro.
Jeremy Garchow
November 19, 2017 at 5:55 pmIs there any background activity happening?
Have you tried on a 23.98 timeline first?
Noah Kadner
November 19, 2017 at 7:02 pmYeah I would definitely boost the memory- 16GB is way low for a Mac Pro.
Noah
Claude Lyneis
November 20, 2017 at 5:13 amI have a mid 11 27″ iMac with 24 GB of ram. I was trying to use compressor with FCPX still running and it virtually stopped. Now I close FCPX and everything else and compressor cranks along. So I think you are right that it is a memory issue. Turn on the activity monitor and it will indicate how much memory is being used.
I am planning to get a new “loaded” iMac. Should I plan on adding 64 MB of RAM (after market of course)? I expect to be using 4k in the future.
Craig Alan
November 20, 2017 at 7:33 amAlso consider the best graphics card you can get.
Imacs (i7); Canon 5D Mark III/70D, Panasonic HPX250P, FCP X 10.3, teach video production in L.A.
Noah Kadner
November 20, 2017 at 4:03 pmiMac Pro is supposed to drop any day now- might want to wait a bit.
Noah
