Activity › Forums › Apple Final Cut Pro › FCPX + DaVinci Resolve Workflow
  • FCPX + DaVinci Resolve Workflow
    Posted by Brian Green on December 12, 2021 at 3:35 am
    Hello!
    This is my first time working with a Colorist.
    I recently edited a project in FCPX. After I locked the cut, I exported an XML and sent the media hard drive to the Colorist.
    The Colorist did his thing in DaVinci Resolve and sent the drive back to me. In a new folder on the drive, he exported the newly graded individual clips, but did not export a new XML.
    How can I relink these new graded clips in FCPX? The timecode should be the same, so can I just unlink the raw clips and relink the new graded clips based on timecode? Or do I need him to export a new XML from DaVinci?
    Thank you!!
    Brian Green replied 4 years, 9 months ago 3 Members · 3 Replies
  • Francois Jean
    December 12, 2021 at 4:34 pm
    You need an fcpxml to achieve the relink, since all these new clips are different from the original shots. if the colourist kept the project he might be able to generate it from the deliver page without any clips … i usually output individual clips with handles just to be safe then generate the new fcpxml related to the rendered clips
    hope this helps
  • Eric Santiago
    December 13, 2021 at 2:25 pm
    Uggh that’s a nightmare especially if it’s a lengthy project.
    I’ve had to manually do it with a music video.
    No way in he|| I will do that again 😛
  • Brian Green
    December 13, 2021 at 8:17 pm
    Yup, looks like I’ll have to do it manually. Luckily, it’s a fairly short spot. Thank you!
