Activity Forums Apple Final Cut Pro FCPX 4K Video Issues
  • FCPX 4K Video Issues
    Posted by Ronald Davis on October 8, 2015 at 6:38 pm
    I’m editing a video project for work, and I’m having trouble importing the video files to FCPX.
    I’ve already done this on my MacBook Pro with no problem and it was only a little choppy because of the RAM on the MacBook. At work we have an iMac computer with a terabyte of space so it shouldn’t be a problem. However NOW when I try to import the files, it adds the audio but not the video. HELP?
    I even moved to Premiere and got the same issue: audio but NO video.
    Ronald Davis replied 10 years, 10 months ago 2 Members · 6 Replies
  • Gerry Fraiberg
    October 8, 2015 at 8:40 pm
    What camera is the video from? Is the iMac running the same version of OSX and FCP X 10.2.2?
  • Ronald Davis
    October 8, 2015 at 11:00 pm
    It’s a Sony MOVCAM 3032702, but I just found out that I need the 10.2.2 version of Final Cut Pro X, which is only available via the updated version of OS X…which for some reason is NOT available for this iMac..
  • Gerry Fraiberg
    October 9, 2015 at 12:21 am
    Movcam is the name of a brand of camera supports. Part #3032702 is a baseplate for the Sony FS7, which records in Sony’s XAVC format. If that’s the camera, you’re right – you will need FCPX 10.2.2 to handle XAVC video clips.
  • Ronald Davis
    October 9, 2015 at 1:49 pm
    Would you happen to know how to update the OS X when it says you can’t?
  • Gerry Fraiberg
    October 9, 2015 at 6:08 pm
    The iMac has to meet System Requirements to upgrade to the latest OSX.
    https://support.apple.com/en-us/HT201475
  • Ronald Davis
    October 9, 2015 at 6:11 pm
    Thanks! Checking this out now.
