Activity › Forums › Creative Community Conversations › FCPX 10.4.1 is out
FCPX 10.4.1 is out
Posted by Mathieu Ghekiere on April 9, 2018 at 3:28 pmI found the release notes here:
https://support.apple.com/en-us/HT201237
“Video noise reduction
Use the high quality, drag-and-drop noise reduction effect to reduce or eliminate grain and video noise
Easily change processing order by dragging the noise reduction effect in the Inspector”Is the video noise reduction effect new? I don’t remember that being available before.
Robin S. kurz replied 8 years, 5 months ago 7 Members · 12 Replies -
Craig Seeman
April 9, 2018 at 3:40 pmAnd they “fixed” the Color Wheels it seems.
Color CorrectionColor wheel sliders retain values at 100 IRE for white and 0 IRE for black, with the ability to move above and below using color correction controls
Simon Ubsdell
April 9, 2018 at 4:05 pm[Craig Seeman] “And they “fixed” the Color Wheels it seems.”
Yes, this does seem to be fixed now.
But a quick look at the Midtones color wheel suggests there is a “kink” in the gamma curve that oversaturates the shadows …
Very noticeable when you compare it to the Color Board.
So not completely fixed.
Simon Ubsdell
tokyo productions
hawaiki -
Robin S. kurz
April 9, 2018 at 4:46 pm[Simon Ubsdell] “Yes, this does seem to be fixed now.”
Question is… does this affect (i.e. change) previous grades done with the wheels? One should assume YES, no?
– RK
____________________________________________________
Deutsch? Hier gibt es ein umfassendes FCP X Training für dich! -
Jeremy Garchow
April 9, 2018 at 5:15 pmBTW, for the late adopters, this release requires High Sierra.
Loren Risker
April 9, 2018 at 5:26 pmDid you see the noise reduction in the release notes? Did they take it out?
OutOfFocus.TV – Music Videos 24/7 -
Simon Ubsdell
April 9, 2018 at 5:29 pm[Robin S. Kurz] “does this affect (i.e. change) previous grades done with the wheels?”
The good news is that when you update your Library to 10.4.1 the existing grades are kept intact.
This is presumably because 10.4.1 is running the “old version” of the color wheels in the background to make sure that none of your grades will be messed up when you update.
Edit: I have found however that exporting an XML from 10.4 to 10.4.1 does not transfer the color wheel information.
Simon Ubsdell
tokyo productions
hawaiki -
Simon Ubsdell
April 9, 2018 at 5:29 pm[Loren Risker] “Did you see the noise reduction in the release notes? Did they take it out?”
There is no noise reduction in this release.
Simon Ubsdell
tokyo productions
hawaiki -
Mathieu Ghekiere
April 9, 2018 at 5:54 pmThe release notes talked about the noise reduction, I copied that text from the release notes. I didn’t find the effect back in the effects panel and apparently it’s taken out of the release notes too. Maybe just a matter of timing, with all the Prores RAW, that they add such an effect.
https://mathieughekiere.wordpress.com
Robin S. kurz
April 9, 2018 at 6:12 pmInteresting. Thanks.
– RK
Youtube | Facebook -
Paul Golden
April 9, 2018 at 9:38 pmNoise reduction was on a feature list earlier today but was removed a little while ago:
