Activity › Forums › Apple Final Cut Pro › FCPX 10.2.1 storage locations popup
  • FCPX 10.2.1 storage locations popup
    Posted by Paul Ireson on July 7, 2015 at 1:01 pm
    I have installed FCPX 10.2.1 (on an iMac, been using previous versions on a Macbook Pro machine for a long time ), and it is dong a new thing that is driving me round the bend.
    Ove and over again, I get the dialogue box:
    Set storage location for the library “Library name”
    with pull-down menus for Media, Cache and Backups locations. ‘OK’ or ‘Close library’ to exit the dialogue.
    It doesn’t matter whether I set a new location, or an old location, or just leave things as ‘In library’, the dialogue is popping up so often it is making it very hard to work with.
    I have tried resetting preferences, and repaired disk permissions.
    Can anyone tell me what’s going on?
    (I’m on 10.10.4, btw)
    Paul Ireson replied 11 years, 2 months ago 4 Members · 5 Replies
  • Noah Kadner
    July 8, 2015 at 2:58 pm
    Try deleting and re-downloading FCPX.
    Noah
    FCPWORKS – FCPX Workflow
    Call Box Training
  • Paul Ireson
    July 8, 2015 at 3:59 pm
    Thanks Noah – I just tried that, but it didn’t seem to make a difference. Same behaviour. Although FCP did lock up (SBBOD while trying to import media) on its first post-re-install run, so I’ll give it another shot
  • Bret Williams
    July 8, 2015 at 9:45 pm
    You might have a drive or directory going bad. Seems like it keeps losing track of the drive or maybe just a directory. Have you repaired the disk?
  • Jeremy Garchow
    July 8, 2015 at 10:30 pm
    Is your library and media on an external disk?
  • Paul Ireson
    July 8, 2015 at 10:54 pm
    No, internal drive only. Though I think an external drive was probably connected at all times. The internal drive is partitioned so I have one 10.6.8 startup disk and one 10.10.4 (in order that I can still use some older software).
    I replaced the internal HD a couple of months ago, so it should be good… maybe I’ll try using Libraries on an external drive and see what happens.
