Activity Forums Apple Final Cut Pro FCPX 10.1 Lag
  • FCPX 10.1 Lag
    Posted by Loren Risker on January 9, 2014 at 1:20 am
    Anyone else struggling with lag?
    Much worse on my machine than 10.0.9
    I’ve closed all libraries except the current one. Wondering if it has something to do with my xsan volume.
    OutOfFocus.TV – Original series, music videos, mini-docs.
    Doug Suiter replied 12 years, 6 months ago 9 Members · 19 Replies
  • 19 Replies
  • Michael Garber
    January 9, 2014 at 6:35 am
    Does restarting FCP bring back the responsiveness? I experienced some lag on a recent project. Restarting the app helped. It would slow down again after some time.
    Michael Garber
    5th Wall – a post production company
    Blog: GARBERSHOP
    My Moviola Webinar on Cutting News in FCP X
  • Loren Risker
    January 9, 2014 at 7:17 pm
    Restarting FCPX or the computer doesn’t seem to help consistently. I also wonder if it lags when it’s creating a library backup.
  • Michael Garber
    January 9, 2014 at 7:22 pm
    Just out of curiosity, how complex is your timeline? Also how many clips do you have in the entire library?
    Michael Garber
    Blog: GARBERSHOP
  • Loren Risker
    January 9, 2014 at 7:27 pm
    This particular project is very small, six 3-minte videos, about 60 minutes from 4 cameras each total. The only filter I’m using is a mask.
  • Michael Garber
    January 9, 2014 at 7:33 pm
    Trying to see what might be similar between your project and mine… Maybe to find the root of the issue.
    Do you have a lot of cuts in your timelines? Are they multicam? How about lots of J- or L-cuts?
    Are the clips 15 minutes each? Or are they broken down into smaller clips?
    I know it’s been said a million times, but I trashed the prefs, fixed the permissions on the boot, and also ran disk warrior on the media drive. Unscientifically, it seemed to help a little bit.
    Michael Garber
    Blog: GARBERSHOP
  • Loren Risker
    January 9, 2014 at 7:37 pm
    It is a multicam project. Minimal angle changes, no l-cuts. Very few connected clips. The multicam clips are less than 5 minutes each.
    As soon as I finish the export I’m going to try trashing everything as you suggest and run my next project on a local drive.
  • Michael Garber
    January 9, 2014 at 7:41 pm
    Well, we both have multicam in common. Maybe that’s a culprit. Update me when you’re done.
    Michael Garber
    Blog: GARBERSHOP
  • Loren Risker
    January 9, 2014 at 8:52 pm
    I tested a locally stored project without multicams and still had log, so hopefully that means our xsan isn’t the problem.
    I then rebooted into recovery, fixed permissions and repaired disks, restarted and trashed all the support files using Digital Rebellion’s preference manager.
    Now the same library is working very smoothly – so maybe it was just something in the preference carried over. I haven’t trashed them since maybe 10.0.6
    Now let’s see if it comes back!
  • Tony West
    January 10, 2014 at 1:31 am
    Seems a little laggy to me also and I don’t have any multi cam clips to deal with.
  • Jason Jenkins
    January 10, 2014 at 2:38 am
    Just curious; did you guys do clean installs of Mavericks?
    Jason Jenkins
    Flowmotion Media
    Video production… with style!
    Check out my Mormon.org profile.
