Activity Forums Apple Final Cut Pro Legacy FCPS2 Assigning Audio Tracks for Output
  • FCPS2 Assigning Audio Tracks for Output
    Posted by John V pappalardo on March 11, 2008 at 9:02 pm
    Being it is the first time I am in need of doing this, I thought I would send my question out to the masses to see what the best options are.
    I am not familiar enough with the audio output for FCP S2 to not need some help. I am reading through the manuals, but as usual the mainly say “yes you can do that” and then leave you hanging.
    I need to output my final 30 minute program with the following audio configurations:
    Channel 1 – Stereo Left
    Channel 2 – Stereo Right
    Channel 3 – Mono Mix Minus (No announcer – Only content, music, sfx, etc.)
    Channel 4 – Mono Mix
    Is anybody doing this on a regular basis? How do I need to configure my FCP S2 audio to be able to get this kind of output?
    Mac OS X 10.5.2 Leopard
    2 x 2.66GHz Dual-Core Intel Xeon
    Final Cut Pro Studio 2 6.0.2
    John V. Pappalardo
    Senior Editor
    Fisher’s ATV World, LTD
    Akira Endo replied 18 years, 1 month ago 3 Members · 2 Replies
  • Shane Ross
    March 11, 2008 at 9:09 pm
    I tend to get my mixes from the audio mixer, so I end up with one file matching each of those perameters. One file that is a two channel stereo mix, one file that is a Mono mix Minus, and one that is the Mono mix. So what you’ll have to so is export audio mixes from your finished sequence as such, so you end up with 4 tracks of audio.
    Then, in the Sequence Settings, Apple-0 (zero) when you click on the AUDIO tab, you can direct what track does what.
    Shane
    GETTING ORGANIZED WITH FINAL CUT PRO DVD now for sale!
    http://www.LFHD.net
    Read my blog!
  • Akira Endo
    July 14, 2008 at 2:19 pm
    I think there is a bug in FCPS2.
    When you change a six-channel-sequence in the sequence-audio-settings from multichannel to two-channel-stereo for example and after that try to change again back to six channels.
    The audio-routing-settings remain to the two-channel setting.
    You have to manually set the routing for each track beginning with channel 3 (eg track3 -> order 3).
    This is very unusefull. Also there is no summarywindow showing all the routing-settings.
    hope it helps.
    cheers
    Akira
