Activity › Forums › Apple Final Cut Pro Legacy › FCPs’ DVCPro HD: 1920 or 1280????
David Coiffier replied 18 years, 11 months ago 9 Members · 33 Replies
Shane Ross
August 18, 2007 at 4:44 pm -
Jeremy Garchow
August 18, 2007 at 4:49 pmYikes. I’m just saying it works, so let’s try and get to the bottom of it. No?
Shane Ross
August 18, 2007 at 4:59 pm -
Tom Brooks
August 18, 2007 at 4:59 pmWhen did this feature go south on you? Are you sure it’s a frame size issue vs. a timebase issue? QT changes the display of various formats based on settings and codec (7.1+ has this whole thing abut Aperture Display Modes), but it doesn’t change the actual frame size unless you tell it to, does it?
FCP4.5 and QT7.2 does not show the problem here.
Jeremy Garchow
August 18, 2007 at 5:04 pmWhat version of OS and QT are you on?
10.4.9, QT 7.1.6 here.
Shane Ross
August 18, 2007 at 5:07 pmTHis feature went south on my After July 24. I exported two self contained movies and took those to a post facility for output. All was fine. 960×720…no rendering when I reimported.
Then ONE WEEK LATER I went to output a separate item…same codec, DVCPRO HD. Only this time it didn’t work. Exported 1280×720 QT that needed to be rendered when I brought it back in.
I updated NOTHING…which is why I am perplexed.
FCP 5.1.2, QT 7.1.3
Shane
Littlefrog Post
http://www.lfhd.net -
J. Tad newberry
August 18, 2007 at 5:42 pmdo you mean the drugs or the software?
FCS 2, with all updates
QT 7.2
thanks again!
mh
J. Tad newberry
August 18, 2007 at 5:47 pmi got the joke (even without the smiley face) and i’m sure Jeremy did, too.
Jeremy, you said you exported them, but in what codec(s)? did you do a QT out, current settings, customize your own? just curious…
thanks again!
mh
