Activity Forums Apple Final Cut Pro FCPEffects Plugin- Organic Light Leak
  • FCPEffects Plugin- Organic Light Leak
    Posted by Sean Mccarthy on December 28, 2013 at 10:56 pm
    Hi- first post, hopefully its in the right location.
    I just downloaded the organic light leak plugin from FCPEffects, and am having trouble achieving the results I want. I am trying to get a flashing light effect for a music vide.. just semi-transparent light streaks at random points throughout the video similar to those seen in the sample video provided at the following link – https://www.fcpeffects.com/collections/new-stuff/products/organic-light-leaks . I unzipped and imported the plugin’s files with ease. Now, in my video filters tab I have a “Light Leak Companion Plugin” and in my library I have the media the plugin proved (blue, green, etc..) My question is mainly procedural. From what I understand I drag and drop the media file over the clip I want it to appear on in my time line. Well then do I just resize it and change the size/transparency to achieve said result over my video? This is method i chose. If it is indeed correct, I am not getting my desired result at all. Also, when do i use the filter, and over what clip? Is you have a link to a step by step of how to use this plugin it would be great, or any advice in general.. I am not too technical an editor.. this is one of my first projects I’m trying to go more in depth with.
    Thanks, Sean
    Sean Mccarthy replied 12 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
