Activity Forums Apple Final Cut Pro Legacy FCP7 Suddenly Won’t Launch, But It Did a Few Days Ago
  • FCP7 Suddenly Won’t Launch, But It Did a Few Days Ago
    Posted by Kevin Patrick on September 19, 2011 at 10:31 am
    I posted this on Apple’s FCP Discussion forum, but didn’t get any responses. So I apologize if you’ve already seen this post.
    For some reason, FCP 7 won’t launch any more. It did just a few days ago. Nothing has changed on my system. When I launch FCP, the startup screen comes up, showing what’s loading. Then nothing. No FCP. Nothing showing in Activity Monitor. I can launch DVDSP. I get the same result with FCP whether I launch the App or double clicking on an FCP project file. It starts to load, but never makes it.
    I can’t re-install FCS, since I’m not running Lion. I had brought FCP over from Snow Leopard.
    I have FCP X installed. But FCP 7 ran fine a few days ago with X installed. FCP 7 was and still is, sitting inside the FCP Studio folder in Applications. Right where FCP X puts it when it gets installed.
    I have tried:
    – Repair permissions.
    – Trashing all FCP preferences.
    Any other suggestion?
    My system: (which hasn’t changed since it did launch only a few days ago)
    Lion 10.7.1
    FCP 7
    FCP X
    ATI 5770
    Quadro 4000 (slave only, no monitor attached)
    24 GB RAM
    Rick Amundson replied 14 years, 11 months ago 3 Members · 5 Replies
  • Jerry Hofmann
    September 19, 2011 at 12:02 pm
    Apple has procedures to follow when installing X and FCS 2009 on the same system: https://support.apple.com/kb/HT4722
    Read that, and give the procedures a go..
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
  • Kevin Patrick
    September 19, 2011 at 12:45 pm
    Thanks Jerry.
    I’m familiar with procedure. I haven’t done it yet. I probably will, if I don’t come across any other suggestions.
    The thing is, FCP 7 was working just fine without having moved it back to the Applications folder. It just stopped loading, with no changes.
    Kevin
  • Kevin Patrick
    September 19, 2011 at 2:39 pm
    Jerry.
    Well, I decided to give it a try. No change. FCP 7 still won’t load. It starts, the splash screen shows what FCP 7 is loading, but it never loads. DVDSP, Compressor and Motion all load fine.
    Any other suggestions?
    Kevin
  • Jerry Hofmann
    September 19, 2011 at 4:37 pm
    Ugh.
    I didn’t load it on the same startup disk as Studio 2009 here… did a separate boot disk for it. Did you do a search in the FCP X techniques forum for the issue? Might try that.
    Jerry
    Current DVD:
  • Rick Amundson
    September 23, 2011 at 6:25 pm
    I’m having the same issue. Just started today. I have un-installed FCP X, I un-installed and re-installed FCP 7. It was working fine yesterday!
    Best of luck!
    Rick Amundson
    Producer/Director/DP
    Screenscape Studios
    Bravo Romeo Entertainment
    http://www.screenscapestudios.com
    http://www.bravoromeo.com
    http://www.indeliblemovie.com
