Activity Forums Apple Final Cut Pro Legacy FCP7 shifts field order
  • FCP7 shifts field order
    Posted by Jan Franzen on August 25, 2009 at 2:36 pm
    just for information FCP7 now changes field order when using “reverse”. Field order can be changed back using filter “shift fields”. If you are only using the Apple screen for monitoring you will not see it before you put it out interlaced thru a i/o card or make a DVD etc.
    Baz Leffler replied 17 years ago 2 Members · 3 Replies
  • Baz Leffler
    August 26, 2009 at 4:30 am
    I bet you are using a Blackmagic card….
    Baz
    What would I do without the ‘UNDO’ button!!!!
  • Jan Franzen
    August 26, 2009 at 1:39 pm
    Yes you are right about that , Black magic Intensity but used with earlier version of FCP, same project, same original, no problem, so what is happening you mean? I have the same problem with the BlueRay DVD when showing on my Sony HD TV .
  • Baz Leffler
    August 26, 2009 at 11:47 pm
    I think the reverse playback field issue will be fixed when Blackmagic release their drivers for FCP 7 – otherwise its the ‘shift fields’ filter.
    Baz
