Activity › Forums › DaVinci Resolve › FCP7 Roundtrip with Alpha-Channels
  • FCP7 Roundtrip with Alpha-Channels
    Posted by Daniel Boist on August 12, 2011 at 12:43 pm
    Hi!
    I need to colorgrade a project which looks like this:
    a FCP7 Sequence with up to 4 Layers. Each Layer, except the lowest Layer (=Background), has an integrated Alpha channel. The clips are in ProRes4444 (keyed and rotoscoped stuff from AE).
    In FCP i did the final edit and “compositing”.
    Exporting XML and conforming that in Resolve works, but “kills” my Alpha-Channels because Resolve ignores embedded Alphas.
    So i need to create a separate Alpha-matte for each clip (which means a lot of additional work) and add
    that as external matte in resolve. Works, but is not very comfortable…
    Sending back to FCP is , in this case, also painful.
    i haven´t found a way to render out a file with alpha (embedded nor separate).
    The only way out is now via “Target”-Mode : means Resolve renders out a single-file which contains all layers.So i can´t do any further (minimal) tweaks in FCP7 (moving/changing Backgrounds etc.).
    Is there a way how i can improve this workflow?
    – Any way to render Alphas out of resolve or a generally smooher roundtrip preserving alphas?
    Thanks in advance,
    daniel
    Joseph Owens replied 15 years, 1 month ago 2 Members · 1 Reply
  • Joseph Owens
    August 12, 2011 at 11:35 pm
    [Daniel Boist] “a generally smooher roundtrip preserving alphas?”
    Imbed the original ProRes4444 with alpha on a layer under your graded clip and you can still use the original clip as an alpha multiplier for the new one.
    jPo
    You mean “Old Ben”? Ben Kenobi?
