Activity › Forums › Apple Final Cut Pro Legacy › FCP7 Media Management
Posted by Greg Jones on July 28, 2009 at 1:49 pmHave any of the brave few who have installed FCP 7 had a chance to see if Media Management works any better than in the past?
Greg Jones
D7,Inc.
Orlando,Fl.
https://www.d7-inc.comBrad Bussé replied 17 years ago 11 Members · 18 Replies -
Jason Brown
July 28, 2009 at 1:55 pmHow about handling renders? I’m assuming/hoping that’s part of media management.
It boggles my mind how bad FCP is at losing reference to renders when you change something…but then put it back. Or just turn off the visibility of a track…render is gone?!
-Jason
Walter Biscardi
July 28, 2009 at 2:16 pm[Jason Brown] “Or just turn off the visibility of a track…render is gone?! “
Well, yeah because you just changed the video. The Render is all the elements in your video track. Turn off a Track and you’ve changed what FCP rendered so it dumps the render. IF you really want that render back, just import the rendered file.
Walter Biscardi, Jr.
Editor, Colorist, Director, Writer, Consultant, Author.
Credits include multiple Emmy, Telly, Aurora and Peabody Awards.
Owner, Biscardi Creative Media featuring HD Post
Biscardi Creative MediaCreative Cow Forum Host:
Apple Final Cut Pro, Apple Motion, Apple Color, AJA Kona, Business & Marketing, Maxx Digital. -
Andy Mees
July 28, 2009 at 2:17 pmA few blog and forum posters have noted complete success in Media Managing complex speed affected sequneces … zero errors. Does that mean you won’t find a problem? I don’t know. But the early reports are good in that regard … here’s one such post by Scott Simmons:
https://provideocoalition.com/index.php/ssimmons/story/kicking_the_tires_on_final_cut_pro_7/ -
Greg Jones
July 28, 2009 at 2:21 pmI guess more specifically I was wondering if they’ve fixed the Media Manager tool. Any time in the past when I’ve attempted to use it to consolidate a project it ends up with errors and I have to manually copy over clips.
Greg Jones
D7,Inc.
Orlando,Fl.
https://www.d7-inc.comGreg Jones
Orlando,Fl.
https://www.d7-inc.com -
Mark Maness
July 28, 2009 at 2:31 pmIn what way have you seen this, Greg?
Are you talking about the fact that it ONLY copies the media but not all of the components inside your project?
As far as I have known, Media Manager only deals with the captured media in the Final Cut Pro Documents – Capture Scratch folder. Its never copied across any of my artwork, music files or Motion projects. I have to do this myself. Now, it would be nice if Media Manager did this, but it never has for myself.
_______________________________
Wayne Carey
Schazam Productions
https://web.mac.com/schazamproductions
schazamproductions@mac.com -
Greg Jones
July 28, 2009 at 2:39 pmCurrently when I attempt to consolidate a project using the media manager and set it to copy media with handles, when the project rebuilds usually there are a few clips that do not copy over correctly. What I usually end up doing is turning off the ‘handles’ and it copies the entire clip over. So if I have a 20 minute clip and only used 2 seconds out of the clip, it copies over the entire 20 minutes. If I turn on ‘Handles’ and try to get it to copy only 2 seconds plus handles, a lot of times I’ll get an error when the project tries to rebuild with the new media. I was just wondering if they’ve fixed this in FCP 7.
Greg Jones
D7,Inc.
Orlando,Fl.
Orlando,Fl.
Jason Brown
July 28, 2009 at 2:48 pm[walter biscardi] “because you just changed the video”
Yea, I got that…but when you turn the visible icon back on…Render is gone? That’s an oversight…FCP has a file that references that EXACT point in the timeline…but when you turn the track visible icon off, then back on…you lose all renders that involve that track. HUGE oversight, IMHO.
-Jason
John Pale
July 28, 2009 at 2:59 pmIf you toggle the clip visibility and not the entire track, you don’t have to re-render the entire track, just the clips involved in the effect.
If you use undo, you don’t even have to re-render.
Shane Ross
July 28, 2009 at 3:16 pmThe MM still requires the media being managed to have a REEL name. Without that, FCP copies the whole clip. Add that and FCP is fine.
Shane
Read my blog, Little Frog in High Def -
Craig Shields
July 28, 2009 at 4:04 pmI’ve always had problems with Soundtrack files not getting copied over. It will usually creates a file called “render” that is useless.
