Activity Forums Apple Final Cut Pro Legacy FCP7: How to edit only audio without unlinking?
  • FCP7: How to edit only audio without unlinking?
    Posted by Sum Choi on February 22, 2013 at 9:36 am
    Sometimes I just want to edit the audio and not the video when I’m making tweaks. Is there a fast way to only select the audio without unlinking using Shift-L? I am not sure if you guys are familiar with Premiere but in Premiere you can select only the audio or the video by holding OPT. Is there a similar function in FCP7?
    Nick Meyers replied 13 years, 7 months ago 5 Members · 4 Replies
  • Rafael Amador
    February 22, 2013 at 12:01 pm
    You can lock the video track.
    The small lock icon at the left.
    rafael
  • Joe Barta iv
    February 22, 2013 at 2:31 pm
    Hold down “Option/ALT” when trimming on the timeline. This will allow you to move the video or audio in/out points independently without unlinking them.
    Bars & Tone
    SALUTE!
  • Bret Williams
    February 22, 2013 at 8:43 pm
    Unless you have linked selection turned off in which case it’s exactly the opposite.
  • Nick Meyers
    February 23, 2013 at 1:06 am
    ” in Premiere you can select only the audio or the video by holding OPT. Is there a similar function in FCP7?”
    yes.
    weird you didn’t just try it!
    ALSO
    Shift L will turn off timeline linking.
    the result of this is that video & audio behave as if independent,
    and in this mode, when you hold OPTION they behave as if linked, a reverse of the default situation.
    nick
