Activity Forums Apple Final Cut Pro Legacy FCP7 FCPX Old 12 core – or new trashcan?
  • FCP7 FCPX Old 12 core – or new trashcan?
    Posted by Terry Flaxton on May 3, 2015 at 5:04 pm
    This is a simple question – will a new trashcan 12 core be better than an old 2012 12 core in the following use:
    SO I shot 40 one minute iphone movies and created an edit with 40 tracks with the images on different parts of the screen (I know – crazy already). by the time I have 20 or so images on screen it takes the old 12 core kit using final cut 7 (studio) 1 – 2 minutes to draw the composite image. (I have 16 gig of ram and older graphics cards in the mac with 6 terrabytes of secondary drive to edit onto). Necessarily I photgraph the screen and work with wireframe only because it takes too long with images. Then when I’ve finished and try output the 1 minute of video it then takes about two days to output. I understand I’m already asking the kit to do more than it was designed for (I come from camera so my knowledge gets hazy at the back end). So my question is twofold – will final cut x on this old system do this a lot faster if I shove in about 32 gig of ram and or will will a new trashcan be the answer – is there anything else I should do to make this work better???
    A long term DP – likes 35mm and HD equally – changing with digital media – Began as a commercials editor !
    Nick Meyers replied 11 years, 4 months ago 2 Members · 1 Reply
  • Nick Meyers
    May 4, 2015 at 4:19 pm
    are you converting your media to Pro Res before you do this?
    h264 might be slowing you down
    nick
