Activity › Forums › Apple Final Cut Pro Legacy › FCP7: Eliminating ProRes 422 File Size Reduction?
Posted by Melanie Price on October 22, 2010 at 3:31 pmIs there a setting in Final Cut that would allow me to export a Pro Res file that’s the same size as the Pro Res file we’re starting with? Currently, we’re seeing a roughly 30% drop in end file size from our original. which seems strange since we’re starting with a ProRes 422 HQ and exporting a Pro Res 422 HQ. Is this normal?
The original was captured from BetaSP off a Sony DVW-A500 right into Final Cut as a Pro Res 422 HQ. The FCP sequence setting matches the file type.
Stevan Pope replied 15 years, 11 months ago 7 Members · 14 Replies -
David Roth weiss
October 22, 2010 at 3:41 pmIn theory, you simply export using Export>>QuickTime Movie, at current settings. How were you doing it before?
David Roth Weiss
Director/Editor/Colorist
David Weiss Productions, Inc.
Los Angeles
http://www.drwfilms.comPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
Colorist – UP IN THE AIR (electronic press kit) – nominated for six academy awards
A forum host of Creative COW’s Business & Marketing and Apple Final Cut Pro forums. Formerly host of the Apple Final Cut Basics, Indie Film & Documentary, and Film History & Appreciations forums.
Melanie Price
October 22, 2010 at 3:46 pmThanks for the reply! We’ve been exporting exactly that way and the Pro Res file we get out of FCP is still roughly 30% smaller than the one we started with. We’ve also tried exporting multiple files via Batch Export with the same results, a ~30% drop in file size.
John Pale
October 22, 2010 at 3:56 pmAre you exporting to a smaller external drive, but capturing to a large drive array? If so, the file sizes can be quite different.
Melanie Price
October 22, 2010 at 4:03 pmWe are capturing from our deck through a Blackmagic Decklink to one system’s scratch disk (~1 TB of free space, 3.6 TB total size) and then another computer accesses the file through the network, and on that second machine it is edited and exported to Machine #2s internal hard drive (~500 GB).
Melanie Price
October 22, 2010 at 4:06 pmPS- The files are small. The captured file is ~2.5 GB and the file we get after the export through FCP is ~1.8 GB. Roughly a four minute clip.
Bret Williams
October 22, 2010 at 4:13 pmAre you per chance capturing 8 tracks of audio and exporting only 2 or zero or something of that nature?
David Roth weiss
October 22, 2010 at 4:19 pmGood call Bret. There has to be some explanation such as that one.
Rafael Amador
October 22, 2010 at 4:32 pm[Melanie Price] “Is there a setting in Final Cut that would allow me to export a Pro Res file that’s the same size as the Pro Res file we’re starting with? Currently, we’re seeing a roughly 30% drop in end file size from our original. which seems strange since we’re starting with a ProRes 422 HQ and exporting a Pro Res 422 HQ. Is this normal?”
A reduction of the file after re-processing Is not strange at all. Is the VBR nature of this codec.
Re-processing works like a “double-pass” compression, optimizing the info/file size.
However a 30% difference I think that may be pointing to something else.
Was FC working in High Precision?
You may be crunching the Prores to 8b somewhere.
Another element that may be a factor, is the BlackMagic.
Those cards are not Prores native.
I guess that if you capture with an AJA you would get a different file size.
rafael -
Olivier Aubut
October 22, 2010 at 4:51 pmI know that snow leopard displays the file-size differently than Leopard. Are you working with both OS?
Melanie Price
October 22, 2010 at 4:58 pmWhen we import the file into Final Cut, it has 4 tracks of audio, and is exported that way. When we re-import the file that has just been exported, it is down to 2 audio tracks. We’ve adjusted the outputs to 4 in the audio settings, and this prompt comes up. We’ve both selected and deselected the downmixing, and either way end up with 2 audio tracks and a drop in file size.
