Activity › Forums › Apple Final Cut Pro Legacy › FCP7 – Editing Film in True 24 vs 23.98
  • FCP7 – Editing Film in True 24 vs 23.98
    Posted by Taylor Levy on August 29, 2014 at 4:32 pm
    Hi folks, thanks in advance for any help.
    I am starting on an feature film shooting 35mm film with a few bits of various digital formats and editing in FCP 7.
    The question is what settings should we cut in.
    Our current plan is make Pro Res Proxy 1920×1080 @ 24fps dailies from the films shot at 24 and the sound recorded at 24. And then cut them in FCP 7 with the sequence set to 24fps.
    But that worries me when we incorporate the digital footage. I’m not sure on the digital camera yet so I’m not positive of there capabilities, i.e frame rates.
    I am sure that whatever they shoot can be made into 23.98 for editorial, but I’m not sure if they can be made into 24fps media that will match the film (and the sound for that matter)
    I’ve don’e 35mm shows before in FCP but the media was always 23.98.
    But everyone on this show is pushing the 24fps workflow.
    Am I right in thinking a true 24fps work flow end to end is best. Or is working in 23.98 best until the conform?
    We are definitely going to make DCPs and a film out is a legitimate possibility.
    Please let me know if I’m missing something here or if you have any experience with this type of workflow.
    -Thanks again
    Nick Meyers replied 12 years, 1 month ago 2 Members · 3 Replies
  • Nick Meyers
    August 29, 2014 at 6:35 pm
    It’s easy to conform your 23.976 assets to true 24fps in CinemaTools
    Nick
  • Taylor Levy
    August 29, 2014 at 11:25 pm
    Thanks for all of you help guys!
    We have decided to work in FCP 7 with 24fps project and sequence settings.
    Turns out all the digital cameras can and will shoot 23.98, and will never be running simultaneously with the film cameras.
    When we shoot digital we will also run sound at 23.98 (48khz).
    After syncing the clips, they will be converted to 24fps for editorial dailies.
    Sound like a decent plan of attack?
    Thanks again,
    -Taylor
  • Nick Meyers
    August 30, 2014 at 1:01 am
    yes: converting will give you picture artefacts, comforting wont!
    for me, conforming is the way to go, but you need to adjust your sync on the audio.
    a simple approach to this is if the sound you shoot with the video is not more than 2 tracks.
    then you can sync your rushes, link & batch export, creating new media that you conform to 24fps.
    you can do a similar thing with multi-track audio, it just gets a bit tricker in FCP.
    nick
