Activity Forums Apple Final Cut Pro Legacy FCP7 edit to tape problem
  • FCP7 edit to tape problem
    Posted by Bruce Little on September 10, 2009 at 5:16 am
    I am having a problem with FCP7 on a new MAC PRO 2.66 / OS 10.5.8
    Kona 3 i/o.
    Mastering to HDCAM OR HDCAM SR same problem.
    Getting picture and sound playing from timeline,
    but as soon as I ‘edit to tape’… I get no sound.
    I’ve tried embedded audio on HDSDI also AES… same issue.
    The audio tracks are armed in the edit to tape window,
    and the tracks are routed properly.
    I have no issues on my FCP6 system.
    Has anyone else had this problem?
    any suggestions?
    thanks
    Bruce
    Bruce Little replied 17 years ago 3 Members · 5 Replies
  • Shane Ross
    September 10, 2009 at 7:02 am
    Have the latest AJA drivers that are for FCP 7? And you aren’t on Snow Leopard are you? If so, got the drivers for that?
    Shane
  • Bruce Little
    September 10, 2009 at 12:59 pm
    Hi Shane,
    Yes, I have the latest FCP7 AJA drivers… also using OS 10.5.8.
    not 10.6.. yet.
    I have also contacted AJA and they have not heard of this problem.
    thanks
    Bruce
  • Liam Lawyer
    September 10, 2009 at 4:50 pm
    Before you go into edit to tape mode, are you seeing the audio going to the deck? That would definitely eliminate the issue of some connection issue.
    Liam Lawyer
    -editor-
  • Bruce Little
    September 10, 2009 at 6:41 pm
    Yes I am seeing audio and video when playing back on the
    timeline. Just issues when in edit to tape.
    I’ve just visited AJA’s website, and I see that there is
    a new KONA 3 driver set, that was released on Sept.1
    I am going to install and see if this fixes the problem
    Bruce
  • Bruce Little
    September 12, 2009 at 8:19 pm
    Problem solved!
    Update Kona driver to version 7, and all works
    Bruce
