Activity › Forums › Apple Final Cut Pro Legacy › FCP7 edit and export settings for DSLR 60D 1280×720 HD 50fps to DV PAL 4:3 MOV
  • FCP7 edit and export settings for DSLR 60D 1280×720 HD 50fps to DV PAL 4:3 MOV
    Posted by Michelle Rabe on March 6, 2015 at 8:20 pm
    My Mac crashed last week so i had to get a new one, problem being that all my settings are now back to default & for the life of me i cannot remember the exact settings i had put in years ago. Ive just watched my first completed edit on my flat screen & the Visual quality is terrible, very pixelated, not smooth motion with hazy lines , major loss of detail esp in the faces of people. Below is my edit process, any help as to where im possibly going wrong would be HUGELY appreciated. Final project goal is to view on a flat screen TV DV PAL 4:3 SD (showing 16:9 wiith letterbox)
    Camera Settings:
    Shoot on Canon 60D
    1280 x 720p HD 50fps PAL
    shutter speed 100
    Converting Process:
    Use Mpeg Streamclip to convert raw footage to Apple ProRes 422
    Use Cinema Tools to conform prores clips from 50fps to 25fps (whole project is edited slo mo)
    Import the slowed down clips into FCP.
    FCP 7 Settings:
    Project settings: DV PAL
    Sequence : DV PAL 25fps 4:3
    Graphics imported as PSD 720×576 300dpi RGB color
    Add a deinterlace filter at max flicker to every clip
    Flicker Max to graphic
    Export:
    Export using Quicktime Movie settings:
    MOV
    DV PAL 4:3
    25fps
    Progressive Scan
    Deinterlace video on
    Quickstart for internet on
    Burn the final clip using DVD Studio Pro DV PAL 4:3
    Michelle Rabe replied 11 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
