Activity › Forums › Apple Final Cut Pro Legacy › FCP7 Crash reports – who can interpret?
  • FCP7 Crash reports – who can interpret?
    Posted by Bob Cole on January 14, 2010 at 4:15 am
    Although I upgraded more carefully than I’ve ever done before (clean new system drive, new install SL, software updates, new install FCP7), I’ve been getting crashes on the SIMPLEST little projects. Today I captured five tapes, rendered a movie, right-clicked on a bin to import that movie -> immediate CRASH. This is after several other little crashes in the two weeks since I installed the new software.
    The only hardware that is different from my old, stable Tiger/FCP6 system is that I also added a new RAID (CalDigit). The crashes have occurred only when running Final Cut.
    FCP generates a crash report, but I don’t know what to make of it, and although it says that it is sending itself to Apple, I doubt that Apple will call and tell me what to do.
    The report is 34 pages long, so I’ll post only a tiny part of it (below). But who can interpret this for me? I’m using a CalDigit RAID + AJA LHe card, but besides that it’s all Apple. AppleCare on the computer expired a year ago.
    Whom would you call to track this problem down?
    Bob C
    — partial report follows:
    Exception Type: EXC_BAD_ACCESS (SIGSEGV)
    Exception Codes: KERN_INVALID_ADDRESS at 0x0000000045c60687
    Crashed Thread: 0 Dispatch queue: com.apple.main-thread
    Thread 0 Crashed: Dispatch queue: com.apple.main-thread
    0 com.apple.QD 0x98b4ff28 QDPlatformLocalToGlobal + 32
    1 com.apple.QD 0x98b4ff06 LocalToGlobal + 26
    2 com.apple.FinalCutPro 0x00150d37 GetGlobalCursorLoc(KGPoint*) + 33
    3 com.apple.FinalCutPro 0x00151122 HandleWheelMove(long, long, long) + 44
    4 com.apple.FinalCutPro 0x0015146e WheelEventHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 488
    5 com.apple.HIToolbox 0x94ed4e29
    Then, about 9 pages later:
    Thread 0 crashed with X86 Thread State (32-bit):
    eax: 0x00010000 ebx: 0x98b4ff1c ecx: 0x4485e000 edx: 0x45c6067f
    edi: 0xbfffdffc esi: 0x0137b2d0 ebp: 0xbfffdfb8 esp: 0xbfffdf50
    ss: 0x0000001f efl: 0x00010286 eip: 0x98b4ff28 cs: 0x00000017
    ds: 0x0000001f es: 0x0000001f fs: 0x00000000 gs: 0x00000037
    cr2: 0x45c60687
    Rafael Amador replied 16 years, 8 months ago 5 Members · 13 Replies
  • 13 Replies
  • Rafael Amador
    January 14, 2010 at 4:25 am
    Hi Bob,
    hopefully the guys in Apple will be able to read that.
    Some times the crash report are easy to interpret because they point to some stuff (Motion or Livetype for example) or plugins that may be causing the troubles, but in general is quite difficult to get a clue.
    Bob, a PERFECT installing doesn’t grants at all that your Mac is in perfect shape.
    After a PERFECT installing (From scratches, repairing permissions after each piece of software gets installed) when ever I run DiskWarrior, I found at least a “30% of Items out of order”.
    So my best advise is you to run DiskWarrior, TechTools or Drive Wizar to clean your HDs directories.
    Cheers,
    Rafael
    http://www.nagavideo.com
  • Bob Cole
    January 14, 2010 at 4:31 am
    Thank you, and a good idea to run Disk Warrior. I did that immediately after the first couple crashes, but I will do it again.
    You say that someone at Apple will be able to read the crash report? Can I actually talk to someone at Apple about a crash report? If I pay for a tech session, as I guess I would have to, I’d like to know that it would help.
    I guess I could start uninstalling AJA and CalDigit cards, but right now I feel like wiping the system drive and going back to FCP6, and perhaps back to Tiger as well.
  • Dan Luke
    January 14, 2010 at 5:01 am
    There is a piece of software that you can download for a 15 day free trial that does a bunch of stuff including interpret crash reports. https://www.digitalrebellion.com/fcs_maintenance.htm
  • Rafael Amador
    January 14, 2010 at 5:16 am
    [Bob Cole] “right now I feel like wiping the system drive and going back to FCP6, and perhaps back to Tiger as well.”
    Bob, you are scaring me. Yesterday I’ve got SL and FC 7. I expect to install it in the next few days.
    But things to check before thinking on re-installing or downgrade:
    Had you installed FC 7.0.1?
    Had you try the “AJA System Test?
    Had you had a look in the Cal-Digit forum (my RAID is a Cal-digit too) if the people is having issues with FC7/SL?
    Rafael
  • Bob Cole
    January 14, 2010 at 5:48 am
    I ran the AJA utility – all it tells me is the speed of the RAIDs.
    Thanks for the tip about Digital Rebellion. I tried the crash analyzer – it couldn’t diagnose, and just invited me to send the crash report to Digital Rebellion.
    I have run the software updates repeatedly, so I assume I have the latest.
    Raf, I would not install SL/FCS unless it were absolutely necessary.
  • Rafael Amador
    January 14, 2010 at 6:46 am
    [Bob Cole] “I ran the AJA utility – all it tells me is the speed of the RAIDs. “
    Sorry I was thinking about the “AJA Conflict Checker”. Never found any conflict in my system, but..
    [Bob Cole] “Raf, I would not install SL/FCS unless it were absolutely necessary.”
    I’ve been reading a lot about and most part of the people are happy about the behave and performance.
    The truth is that for my work I don’t need it but I have the feeling that I’m getting behind everybody.
    people talk about things in the forum and I don’t know whats going on.
    I will think about.
    Cheers,
    rafael
  • Michael Gissing
    January 14, 2010 at 7:16 am
    I am running Snow & 7.0.1 and very happy. Main improvement for me is Color 1.5.1 which is running really well.
    That said I am running an internal RAID not esata or fibre. I do use external FW800 drives.
  • Jeremy Garchow
    January 14, 2010 at 1:08 pm
    Bob what kind of computer do you have and what slots are your pci cards in?
    Also, do you have a third party mouse?
  • Bob Cole
    January 14, 2010 at 9:03 pm
    Good question. When I went through the list, I noticed that although I tried to upgrade the firmware on my CalDigit RAID card, apparently it didn’t “take.” I’m not sure whether the list is wrong or the firmware, because the list says, literally (with the additional “.”) “2.0.”. The current firmware is 2.0.2. Although the RAID works, I think I’m going to focus on the CalDigit for awhile; its RAIDShield software calls the current configuration “unsupported,” which is not a good sign.
    Here’s the list:
    2×3 GHz Dual-Core Intel
    9 GB 667 MHz DDR2 FB-DIMM
    original DVD burner (Sony)
    NVIDIA GeForce 7300 GT
    CalDigit SCSI(?) RAID card Revision 2.0.
    (but under the Hardware RAID section of the MacPro list of hardware, it reads “This system doesn’t contain any supported hardware RAID devices. If you installed hardware RAID devices, make sure you installed them properly.”)
    HDOne 8 TB
    Apple keyboard – plugged in via one 6-foot extender
    Apple mouse
    Expansion Slot Utility:
    4: Unknown RAID Controller Card (CalDigit RAID card)
    3: Intel PCI-to PCI Bridge Card (AJA Kona LHe)
    2: no card detected
    1: NVIDIA GEFORCE 7300 GT
    Bob C
  • Jeremy Garchow
    January 14, 2010 at 9:10 pm
    Yeah, looks like you nailed it. Now, make sure you have the slots in the right config according to this diagram:
    https://www.aja.com/support/kona/kona-system-configuration.php
    Then make sure the you run the Slot Config Utility (System > Library > Core Services) as I think you have an older MacPro. I have the same one. Make sure that it’s running option 2. If a warning comes up and says that you can’t run it, then you’re going to want to put the Kona in Slot 2 and storage in 3 or 4.
    Jeremy
