Activity Forums Apple Final Cut Pro Legacy FCP7 Clips Unrendered
  • FCP7 Clips Unrendered
    Posted by Gerald Collison on October 8, 2010 at 10:15 pm
    I’ve got a clip that I captured to FCP 7. I don’t think I had 48kHz “Anamorphic” just NTSC DV 48kHz selected as the capture settings, but I dont think that would make a differnce. Please tell me if I’m wrong. But the clip settings match the timeline,
    720×480, DV/DVCPRO-NT, Data Rate only shows up on clip (3.6MB/sec), NTSC – CCIR 601, and Both Anamorphic’s are checked for sequence and clip. Everything matches up except for Audio format, sequence being 32-bit Floating Point and Clip being 16-Bit interger.
    Everytime I drag the clip to the timeline, however, it is unrendered? What gives? I can’t figure out why the clip is unrendered. Any help would be greatly appreciated!
    Jeremy Garchow replied 15 years, 11 months ago 2 Members · 1 Reply
  • Jeremy Garchow
    October 8, 2010 at 10:32 pm
    Is there a filter?
    Motion tab values not what they should be?
    If you load a clip from the browser and make adjustments, that sticks with the master clip. If you put the clip on a timeline, it won’t.
