Activity Forums Apple Final Cut Pro Legacy FCP7 Canvas defaults to ALPHA channel???
  • Bret Williams
    January 7, 2012 at 5:43 am
    It’s right there in the canvas pulldown menus. There are hot keys. You’re probably inadvertently hitting one.
  • Eric Schlenker
    January 20, 2012 at 5:46 pm
    Same thing just happened to me, SO ANNOYING! I’m pretty sure I fumbled a shortcut but I have no clue what keys I hit to switch it back. The canvas window now defaults to the white alpha for every sequence until you switch it back to RGB. Easy enough to switch, but if I have to do it every time I open a sequence it’ll drive me mad!
    I’ll probably get nothing else done on this project until I rat out the varmint shortcut and get it back in order.
