Activity Forums Apple Final Cut Pro Legacy FCP7 / Canon 5D MK II edit/render problems
  • FCP7 / Canon 5D MK II edit/render problems
    Posted by Tom Mcafee on March 16, 2012 at 4:55 am
    All,
    I’m transitioning from using a Z-1 / mini DV tape to a Canon 5D MK II / Compact Flash, and speaking of transitions — I’m doing a little test that’s proving to be more of a learning experience than I had in mind . . .
    What’s happening is this: each and every transition I make needs to be rendered, and unfortunately that’s about 98% of this little video, or say, 100 edits @ 15 seconds/render — in other words, fergettabouddit. To make matters worse, at the end of each transition , i.e. the point at which the dissolve from clip A to clip B is complete, the image stutters and jumps back a frame or two, not exactly the smooth, silky effect I had in mind. In addition, when I drop in the MP3 music track, that needs to be rendered as well.
    All I know is this doesn’t happen when I shoot & edit using tape, so I assume this may have to do with the capture procedure and/or settings.
    What I did is this:
    (1) attached camera to my laptop via firewire, which automatically captured the clips using Aperture (is this a problem, and/or is there a better way?).
    (2) exported the master .MOV files to my desktop, and then
    (3) imported the files into FCP (7.0.3).
    When I made the first edit / dragged the first clip into the timeline sequence, I got a pop-up message,
    “this clip does not match your sequence settings, etc.:” — I assume this is The Big Clue as to what’s going on, but I don’t know what to do at this point, what settings to adjust etc. I clicked “Yes” to change the settings to match, and got the results described above, Render Hell. I checked the sequence settings against the clips using Q/T player 7, and as far as I could tell they seemed to match. However, I couldn’t find anything on the sequence settings having to do with data rate or data size — could this be the smoking parameter?
    So, does anyone have any idea what I’m doing wrong and how to fix this, or is this just a Mercury-in-retrograde issue?
    Many thanks,
    Tom McAfee
    Neil Patience replied 14 years, 5 months ago 4 Members · 14 Replies
  • 14 Replies
  • Stephen Smith
    March 16, 2012 at 3:17 pm
    Cannon has a plug-in so you can log and transfer in FCP. It works great and will make editing smooth and easy for you again. Check out this tutorial from Shane Ross: https://library.creativecow.net/ross_shane/tapeless-workflow_fcp-7/1
    Best of luck.
    Stephen Smith
    Utah Video Productions
    Check out my Vimeo page
  • Tom Mcafee
    March 16, 2012 at 3:27 pm
    lovely, thanks, I’ll check it out.
  • Stephen Smith
    March 16, 2012 at 4:00 pm
    Cool, best of luck.
    Stephen Smith
  • Tom Mcafee
    March 16, 2012 at 5:12 pm
    Steven, another very, very basic question: how do I get the files to my computer in the first place? In the past, Aperture has downloaded/imported the files automatically because I had it set up to open whenever a camera is attached. Should I then just export the .mov files to my desktop for further processing/coversion, or should I avoid the Aperture step altogether? Trouble is, when I turn off the Aperture auto-launch, nothing shows up and I can’t find the camera’s platform icon anywhere. Any ideas?
    Tom
  • Stephen Smith
    March 16, 2012 at 5:17 pm
    I create a new folder and name it. Then drag everything from the camera to that folder. Certain cameras like the T2i create a DCIM folder. Keep every thing as the camera has it. Then instal the plug-in from Cannon. Open up the Log and Transfer window and you are ready to go.
    Stephen Smith
  • Brent Dunn
    March 16, 2012 at 6:31 pm
    It’s best to lock your card before inserting it on a Mac. Mac’s will write a program onto the card. I haven’t had an issue with this, but some people have.
    Don’t use Aperture for capturing video. Just plug in your card to your card reader and open the drive mounted on your desktop.
    Make yourself a folder for your project and then a subfolder for each card with the proper labling for your shoot.
    Drag the entire contents of your card into the folder you created to copy it over. Some people use another program to do this which checks the transfer data against the card. I’ve heard of some people having some of the data not being transferred. I’ve not had this problem.
    Once you copied your cards over onto your computer. Then you can start a project and use the log and transfer plugin to import and properly format your video clips to ProRes for editing.
    Brent Dunn
    Owner / Director / Editor
    DunnRight Films
    DunnRight Video.com
    Video Marketing Toolbox.net
    Sony EX-1,
    Canon 5D Mark II
    Canon 7D
    Mac Pro Tower, Quad Core,
    with Final Cut Studio
    HP i7 Quad laptop
    Adobe CS-5 Production Suite
  • Tom Mcafee
    March 17, 2012 at 6:04 am
    Stephen, sorry to be dense, but . . . you lose me at the point where you say “Then instal the plug-in from Cannon. Open up the Log and Transfer window and you are ready to go.” I’m following Shane’s tutorial as you suggested, downloaded the Canon plug-in and the icon is sitting there on my desktop — but how do I introduce it to FCP? I opened my FCP project > log & transfer, checked the import preferences by clicking on the “sprocket” as Shane demonstrates; however, there’s no Canon option in my source format list, only “MPEG2 consumer cameras, P2 Plugin, and AVCHD plugin”, a so apparently the Canon plugin didn’t get installed or connected to FCP — just to be sure I tried to do the “add volume” step, but when I selected the DCMI file a pop-up warning said the format wasn’t supported. It’s just not clear to me how to use the plugin. I’m sure there’s a very basic maneuver I’m leaving out?
    Thanks again, Tom
  • Tom Mcafee
    March 17, 2012 at 6:25 am
    Stephen, never mind . . . I brilliantly discovered that if I double click the canon plugin icon, voila, it gets installed, and like you say, off I go . . . sheesh. Thanks.
  • Tom Mcafee
    March 17, 2012 at 6:49 am
    New render problem, not quite as bad, but — I successfully accomplished a test transfer of two clips (thank you very much), put them in a timeline, applied a x-dissolve, and now instead of the red “not rendered” line at the top of the timeline, I have a green “sort of rendered” line, and it jerks and fits its way through the edit until I render it, a 20 second process for a three second dissolve. Once rendered it’s beautiful , but this seems like a hell of a way to have to edit. Is this a function of my computer’s processor, or is there a fix for this? This never happened when I was using tape. Thanks, Tom
  • Neil Patience
    March 17, 2012 at 12:44 pm
    The green bar indicates a real time effect. So your system can play it in real time however is having to work at doing that hence the drop in quality or stuttering.
    At the point of the dissolve you are having to access and playback 2 HD streams at the same time. My first thought is that your drive(s) are not quick ebough to access that. Clearly the single streeam is fine and once rendered (also then a single stream) is also fine.
    What ProRes codec are you transcoding to ? 422 LT and 422 are usually good enough for 5D footage.
    What kind of hard drive are you using for media and how is it interfaced ? Hopefully you are not using the internal OS drive.
    For ProRes you really need 7200 rpm drives and firewire 800 is the bare minimum in terms of speed.
    Once you start adding multiple HD streams you really need to start looking at faster drive interfaces, esata, raids etc etc or you will always have stuttery unrendered playback.
    best wishes
    Neil
    http://www.patience.tv
