Activity Forums DaVinci Resolve FCP7 and DaVinci on the same machine
  • FCP7 and DaVinci on the same machine
    Posted by Charlie Seetoh on December 1, 2011 at 5:47 pm
    I’m running FCP7 on a single ATI 4780 and planning to replace it with the 2 Nividia card for Resolve.
    Will there be a problem running FCP7 and Resolve on the same mac pro with 2 graphic cards like Nividia GT120 and GTX470. I was told that I’ll encounter problems as FCP don’t work well with 2 graphic card installed.
    thanks
    Chris Jones replied 14 years, 9 months ago 5 Members · 4 Replies
  • Eric Johnson
    December 1, 2011 at 5:55 pm
    works fine for me.
    Mac Pro 5,1
    ATI 5770/Quadra 4000
    DaVinci 8.1.1
    FCP 7.0.3
  • Margus Voll
    December 2, 2011 at 8:27 am
    I have 120 and 4000 and i even use 4000 as my secondary display gpu connected only with fcp session
    and all works well.
    Margus
    https://iconstudios.eu
  • Paul Jay
    December 2, 2011 at 8:55 am
    It Just works.
  • Chris Jones
    December 2, 2011 at 5:07 pm
    FCP7 Works fine but I didn’t like having to connect to my viewing monitor using the decklink card instead using it as an extended monitor.
    You have to constantly change the Blackmagic output settings whenever your sequence settings change instead of just setting output to “Preview” for everything. Also, I liked taking full screen screenshots in FCP and couldn’t after connecting through the decklink card.
    You can still connect if you have a third monitor for scopes, which I do, but it was a cheap monitor. In the end I switch the cables when working with FCP and Resolve. I prefer to connect to my viewing/grading monitor using “preview” over the decklink card when editing in FCP.
    But in direct answer to your question. I have never had a problem running FCP and 2 cards.
