Activity › Forums › Apple Final Cut Pro Legacy › FCP6 supports multi-core rendering ?
Posted by Christopher Tay on May 22, 2007 at 1:45 amHi,
I could have missed this at NAB but does FCP6 support all the CPU cores during rendering, especially with the new 8 cores Mac Pro ?
-chrispy
Justin Miller replied 17 years, 3 months ago 10 Members · 18 Replies -
Nate
May 22, 2007 at 2:08 amFrom what I have read, WAIT till Leopard…… that is the next OS , right..
Jerry Hofmann
May 22, 2007 at 11:57 amCompressor will definitely take advantage of as many as you have now… You can actually send an instance of your compression job to each of the 8 in an octo…
Jerry
Apple Certified Trainer
Author: “Jerry Hofmann on Final Cut Pro 4” Click here
Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
Chi-ho Lee
May 22, 2007 at 12:27 pm[Jerry Hofmann] “You can actually send an instance of your compression job to each of the 8 in an octo…”
People have been touting that feature as multi-core aware, but that only helps when you have 8 movies to compress. But what if I only have one movie to compress? Doesn’t sound like all 8 cores will kick in to help compress one single movie….right?
CHL
Chi-Ho Lee
Film & Video Editor
Apple Certified Final Cut Pro Trainer
http://www.chiholee.com -
Walter Biscardi
May 22, 2007 at 12:33 pm[Chi-Ho Lee] “People have been touting that feature as multi-core aware, but that only helps when you have 8 movies to compress. But what if I only have one movie to compress? Doesn’t sound like all 8 cores will kick in to help compress one single movie….right?”
You weren’t at NAB were you? Jerry is talking about ONE job being fed out to all 8 cores. That’s the demo they were showing at NAB so yes, all 8 cores will kick in on ONE single file.
Walter Biscardi, Jr.
HD Editorial & Animation for Broadcast and independent productions.All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
Read my blog! https://blogs.creativecow.net/WalterBiscardi
Walter Biscardi
May 22, 2007 at 12:35 pm[chrispy] “I could have missed this at NAB but does FCP6 support all the CPU cores during rendering, especially with the new 8 cores Mac Pro ?”
As far as I could tell, Apple was silent on this and only showed Compressor taking advantage of all 8 cores. My guess is that this may show up with Leopard whenever that ships.
Chi-ho Lee
May 22, 2007 at 12:45 pmJerry, what’s the deal with the instances then?
I have to manually activate each instances? How? Via a menu option? Open up Compressor twice or 4 or 8 times?
CHL
Chi-Ho Lee
Film & Video Editor
Walter Biscardi
May 22, 2007 at 12:46 pm[Chi-Ho Lee] “Jerry, what’s the deal with the instances then?
I have to manually activate each instances? How? Via a menu option? Open up Compressor twice or 4 or 8 times?”
Just look at the manual when you get it. I believe the demo artist just created 7 aliases of Compressor for each core and away it went.
Jerry Hofmann
May 22, 2007 at 12:46 pmThe demo at NAB showed ONE sequence being sent to all 8 processors… Apple showed this being compressed to H.264… it was 3 times speed. i.e. a 9 minute sequence would compress in 3 minutes… I’m sure too if you have only 4 the same thing can happen, however at half the speed or so…
Jerry
Jerry Hofmann
May 22, 2007 at 12:52 pmI don’t think so… it works NOW… (remember that dashboard speed thingy? it was way cool too…there’s a command you can pull up … I just missed where this is, but Compressor 3 doesn’t have that many menus etc… look there and I’ll wager you’ll find it. or open the manual…? I’d do it, but have to wait just a few days before I can.
Jerry
Walter Biscardi
May 22, 2007 at 1:10 pm[Jerry Hofmann] “I don’t think so… it works NOW… (r”
In Compressor yes. Chrispy was asking about Final Cut Pro 6.
