Activity Forums Apple Final Cut Pro Legacy FCP6 “Rename file to match clip” function being weird.
  • FCP6 “Rename file to match clip” function being weird.
    Posted by Hugh Sundae on May 4, 2009 at 3:23 am
    I’ve searched COW regarding this, and perhaps this is just simply a bug, and I should only use the FC6 Rename function in smaller batches, but here goes anyway..
    After laboriously going through my captured reel’s last night and giving each clip a proper name based on the slate info eg EP2_19_1_1_A and then selecting all the clips and doing a “rename file to match clip”, I have opened my project today to find a whole bunch of missing connections.
    A small heart attack as I’d gone into my capture scratch after to check they had all renamed correctly.
    What I find really strange, is when I select a clip to reconnect, it’s still in the browser as what I changed it to (like the above eg) and it still is in the capture scratch – so i don’t know why the connection was lost.
    Stranger still – the file name that it asks me to find when I reconnect is it’s name before it was changed.
    To try and make this sound clearer…
    The file was captured as B
    I renamed the clip in the browser from B to A.
    I used the rename file to match clip function to change the file to A
    And now – the file and clip are both named A, but it’s asking me to find B
    confused? I am.
    please help!
    Cheers
    Hugh
    Hugh Sundae replied 17 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
