Activity › Forums › Apple Final Cut Pro Legacy › FCP6, HDV
FCP6, HDV
Posted by Paul Diffley on December 21, 2007 at 7:47 pmFCP6, HDV
Paul Diffley replied 18 years, 8 months ago 3 Members · 3 Replies -
Jeff Carpenter
December 21, 2007 at 7:55 pmStay away from HDV. You can always buy more hard drive space later.
As an alternative, check out Apple’s Intermediate Codec. You can also capture to it live from firewire. It’s essentially the same as HDV but all i-frames, so it’s easier to work with.
It’s not quite as nice as Pro-res, but the size is a little bit better. You should at least try some tests and compare it to Pro-Res and see how the results compare.
Paul Diffley
December 22, 2007 at 5:01 pmThanks Jeff and David, much appreciated.
I’ve now started my capture using ProRes.
Paul
