Activity Forums Apple Final Cut Pro Legacy FCP6 cutting sequences into sequences
  • FCP6 cutting sequences into sequences
    Posted by Chris Gernon on July 13, 2007 at 1:29 am
    this used to work perfectly in FCP5.. where as you load a seq into the viewer.. and while hitting the apple key as you drag the seq from the viewer to the canvas.. it’ll insert or overwrite depending on what you choose all the edits (non-collapsed) across… however with FCP6 it seems to mess up the sync. by moving the audio 1 frm out and sometimes moving or inserting (not sure which) one frame of space between cuts. As well as audio (in my case music) that has reconnected to a differnt part of the track.. this is really odd, and i’m sure a bug. Has anyone else experienced this? If so i’d like to hear what you’ve found out.
    oh.. yes i’ve also experienced with a cut and paste from one seq to another that audio levels have moved as well. level keyframes mostly will shift to different setting on the same track.
    if that makes any sense.
    thanks
    chris
    Chris Gernon replied 19 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
