Activity Forums Apple Final Cut Pro Legacy fcp5 won’t let me render
  • fcp5 won’t let me render
    Posted by Eli Mavros on August 12, 2005 at 10:57 pm
    Hey guys,
    I just upgraded to ver 5. I opened a project from 4.5 and it said that the render files should be updated and asked me what quality I would like to render at (which I didn’t even know was ever a choice!). I chose best (and tried normal). Then when I open the seq there are red bars all over the place, but when I try to Render All, nothing happens…the render progress bar wizes by, and the timeline is still all red. Bug? Why can i not render? I have also tried to do Render In to Out, etc.. No dice. I hope someone has a solution.
    Eli
    David Rowan replied 21 years, 1 month ago 5 Members · 4 Replies
  • Jerry Hofmann
    August 13, 2005 at 1:36 am
    Try opening the project again, and turn ON the delete render files. FCP 4.5 used the “fast” setting (lowest quality) new to FCP 5 is the normal setting (better than before) but you should trash the older renders and re render. Then there’s highest qualtiy, which again you should trash the old renders (there’s a checkbox in the bottom of that window to turn on for this during the update procedure). Each of the two higher quality render settings will take more time (more computations for better quality). Otherwise, if you set it to fastest, then don’t delete older renders, it should open with the old renders intact. BUT you probably have already trashed these old renders the first time you opened the file. but it might be worth the try to make sure that the delete render files option IS turned on, that way the system thinks that the sequences need to be re rendered and will do so. It sort of sounds like, it thinks those old render files are still there, when they really aren’t.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Phillip Van west
    August 13, 2005 at 5:33 am
    Are you sure you have all the render types checked in the ‘Render’ and ‘Render All’ submenus under the Sequence Menu? You probably do, but it never hurts to ask…
    pvw
    Phil Van West
    Terra Nova Productions LLC
    Denver, CO
    Video Production/Post-Production
    G5 DP 2.5GHz / 4.5 GB RAM / 2x250GB SATA / OS 10.4.1 / FCP 5.0 / QT 7.0.1
  • Andy Mees
    August 13, 2005 at 5:54 am
    this can sometimes be an issue with incorrect permissions on your render directory.
    if you’re in a multiple user setup, make sure that you have Read & Write access for the enclosing folder of your Render Files directory.
    cheers
    Andy
  • David Rowan
    August 15, 2005 at 2:13 am
    In FCP 4.5 I rendered all by hitting “Apple-R” I was baffled when this didn’t work in FCP 5. It turns out that now I have to hit “Option-R”.
    I also had to make sure that under the menue for Sequence-render- That all the choices were check marked. Sometimes they are not all checked, so nothing happens.
    DWR
