Activity Forums Apple Final Cut Pro Legacy fcp5 i don’t have mpeg2 export option
  • fcp5 i don’t have mpeg2 export option
    Posted by Vgrafr on June 25, 2007 at 7:53 pm
    i have fcp5.0.1 and according to the manual i should have the option to export in mpeg2. but the option is not there. does anyone know why??
    plus compressor strips my audio when i try and make an mpeg2. any thoughts
    John Pale replied 19 years, 3 months ago 4 Members · 5 Replies
  • Jerry Hofmann
    June 25, 2007 at 8:51 pm
    Update to 5.0.4… as a side note, it’s full of bug fixes.
    What flavor of MPEG are you needing to create? For a DVD burn or?
    Jerry
  • Vgrafr
    June 25, 2007 at 9:01 pm
    i do have 5.0.4 i need to make mpeg2 to upload to an ftp site
  • Jerry Hofmann
    June 25, 2007 at 9:14 pm
    Compressor 3 will make a transport stream… which is what you’re talking about. I can’t remember if 2 does or not, but search the online manual for it on the word “Transport”. If it does it, you’ll see the procedure.
    There is multiplexing software out there to do this, but I figure we should see what you can do for free first, eh?
    Jerry
  • Chris Borjis
    June 25, 2007 at 10:13 pm
    [Jerry Hofmann] “Compressor 3 will make a transport stream”
    Jerry do you mean a multiplexed (1 file with video+audio) mpeg file?
    Transport Streams are typically HD and Program Streams are typically SD.
    That would sure be nice if compressor 3 actually had the ability to build a muxed file instead of separate streams.
  • John Pale
    June 26, 2007 at 12:19 am
    [Borjis] “hat would sure be nice if compressor 3 actually had the ability to build a muxed file instead of separate streams.”
    It does.
