Activity Forums Compression Techniques FCP5 HDV to Sorenson 3 Quicktime via CM 3.1.2
  • FCP5 HDV to Sorenson 3 Quicktime via CM 3.1.2
    Posted by Twistlick on October 2, 2005 at 5:01 pm
    I’ve got a Sony HDV camera and I’m trying to compress some shots that I loaded into FCP5 down to quicktime movies (Sorenson 3 codec) using CM3.1.2. The movies turn out stuttering, one frame forward, two frames back, 3 frames forward etc. I’ve exported the files out of FCP5 as QT reference movies and also tried the original HDV quicktime but the same thing happens. I assume it has to do with the MPEG compression of HDV but how can I compress smooth playing quicktimes from HDV? Any suggestions?
    Ben Waggoner replied 20 years, 11 months ago 2 Members · 1 Reply
  • Ben Waggoner
    October 3, 2005 at 6:25 pm
    Sounds like you’ve flagged the field order wrong in the deinterlace field. Try switching from/to upper/lower.
    I honestly haven’t tested HDV with CM 3.1.2 yet, so I’m not sure what caveats there are for it.
