Activity Forums Apple Final Cut Pro Legacy Fcp5 Capture Now duration
  • Fcp5 Capture Now duration
    Posted by James Ryan on July 20, 2009 at 2:22 pm
    I am trying to capture an entire tape with FCP 5. I am using a Sony DSR-25 and the tape is a Sony DVCAM 184. The tape does have timecode breaks, so I thought it best to use Capture Now. However, when the process is complete, I find that the file is not the entire duration. I have actually watched, and it seems to be capturing everything on the tape. It goes to the need of the tape and does not give me any error messages. I eventually got it to capture in 3 blocks. I suppose I could live with that, however I have many hours of tape to capture from a 3 camera shoot, and I would rather not babysit the process.
    I have all timecode break warning boxes unchecked and no duration set to Capture Now. Any thoughts as to why Capture Now seems to be limiting the duration of the capture.
    Thank You!
    John Fishback
    replied 17 years, 1 month ago
    2 Members · 1 Reply
  • John Fishback
    July 20, 2009 at 4:14 pm
    How is your scapture scratch drive formatted? What codec are you capturing in? It always helps to describe your system and software versions.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
