Activity Forums Apple Final Cut Pro Legacy FCP4.5 crashes while loading a FCP project – HELP
  • FCP4.5 crashes while loading a FCP project – HELP
    Posted by Thomas Yong on October 1, 2005 at 5:50 am
    Hi forum,
    I have been editing two short films using wo separate external Hard Drives (D2Lacie and Lacie Porche) connected to my Mac. I am running Mac G4 1.25DP, 1gig RAM, Sony DSR11, Sony broadcast monitor. I am running Mac OS X.3.9.
    Everything went really well with these two projects. Howeverm two weeks ago I accidently accepted an automatic security and Quicktime update . I now run Quicktime in version 7.2 (or something).
    When I tried to load my FCP project into FCP4.5HD, FCP4.5HD starts to opens and the program gets uploaded until 13% then the program crashes. THis also happens with my other project.
    Anyone who has some explanations of what can be done???
    I reinstalled OX10.3.9 and then I reinstalled Final Cut Pro 4.5HD. But still the system crashes………
    HEEEELLPPPPPPP.
    THomas
    Debe replied 20 years, 12 months ago 2 Members · 3 Replies
  • Debe
    October 1, 2005 at 6:07 am
    You need to remove QT 7. It doesn’t work with FCP 4.5.
    Reinstalling the OS or FCP won’t necessarily overwrite QT7
    https://www.apple.com/support/downloads/quicktime652reinstallerforquicktime70.html
    or
    https://www.apple.com/support/downloads/quicktime652reinstallerforquicktime701.html
    depending on which version of QT 7 was installed.
    debe
  • Thomas Yong
    October 2, 2005 at 1:37 am
    Debe,
    Thanks for your response.
    QuickTime was in QT 6.5.1 so I took it to QT7.02. I used your links to take it down to QT7.01 and then to QT6.5.2.
    But I still can’t load my FCP projects. Not even from the AutoSave vault.
    Help………
  • Debe
    October 2, 2005 at 5:50 pm
    Sorry to leave you hanging, Thomas. I’ve been having troubles with Creative Cow occasionally where it won’t load. I get access to other parts of the internet, and when I finally can get back in to the Cow, there are lots of new posts, so it’s not that the site was down…it’s just for some reason I can’t get in.
    Anyway, have you tried trashing preferences and repairing permissions? Repairing permissions is especially important after installing/uninstalling software.
    Repairing permissions is done in Disk Utility usually located in [main hard drive]>Applications>Utilities.
    For info on trashing prefs, look at this site…
    https://www.lafcpug.org/trashing_fcp_prefs.html
    The following is a nifty little program that stores and trashes prefs for you. Just be careful backing up the first time. Make sure you’re backing up clean prefs.
    https://fcprescue.andersholck.com/
    debe
