Activity › Forums › Apple Final Cut Pro Legacy › FCP2 sends entire clip to Soundtrack
  • FCP2 sends entire clip to Soundtrack
    Posted by Alex Guimoye on February 22, 2008 at 1:38 am
    I am trying to boost the gain on a clip and take away the noise. I am completely new to Soundtrack and don’t have too much experience using FCP2 (I was a PC guy till recently)
    This is what I’ve gotten so far. I used the blade tool to and cut to points on a clip and select it. Then I control + click and with the mouse select “send to” then “Soundtrack Pro Audio File Project.” This loads up Soundtrack Pro and imports the ENTIRE clip (a whole mini dv tape) into a timeline. How do I get FCS2 to just send the portion of a clip I highlight?
    Thanks.
    Alex Guimoye replied 18 years, 7 months ago 3 Members · 4 Replies
  • Richard Martz
    February 22, 2008 at 2:19 am
    Open a new sequence. Copy only that section to the New sequence then export to SoundTrack it should work fine.
    Richard Martz
    MagicMartz Media
    Final Cut Pro HD
    Kona LH
    After Effects
    PhotoShop
    Illustrator
    Lots of other Fun Stuff!
  • Zak Mussig
    February 22, 2008 at 5:20 pm
    That would technically work, but would be tedious if you’re dealing with multiple clips.
    The real method is to check the box that says “Send only referenced media” in the dialog box that pops up when you select the “send to soundtrack audio file project” command. You can even set the duration of your handles, but I always keep the default 10 sec on either side. These are helpful when you’re going to Soundtrack to remove background noise as something on either side of your clip is more likely to contain a few clean seconds of background noise.
    Zak
  • Alex Guimoye
    February 22, 2008 at 8:09 pm
    You the man Zak. I followed your advice and got it to work just fine. Now its just a matter of playing around with the noise reduction and it will be good to go!
    Alex.
    Alex Guimoye
    1SourceMedia.com
    916. 502. 0042
  • Alex Guimoye
    February 22, 2008 at 8:12 pm
    Hi Richard,
    I tried doing this but it still exports the entire clip. However I got it to work by checking the box that reads “send only referenced media”
    Thank you so much for your post.
    Alex.
    Alex Guimoye
    1SourceMedia.com
    916. 502. 0042
