Activity › Forums › Apple Final Cut Pro Legacy › FCP XML into Redcine X FAIL – Can anyone heIp me out?
Posted by Jason Armstrong on August 25, 2011 at 5:33 pmI have cut a film trailer (using proxies) in FCP 7. I exported an XML (version 5) and tried to import it into Redcine X. Redcine X asks me to double click to link original files. I do a couple and it doesn’t autolink. If I then press ok, Redcine X just shuts off. EVERY TIME.
Can anyone help me out? I want to do a light grade before rendering out and sending for CC.
JJeremy Garchow replied 15 years ago 2 Members · 22 Replies -
Jason Armstrong
August 25, 2011 at 6:01 pmCan you tell me how that works? I downloaded version 2.2 but can’t decipher where to go after relinking.
Jeremy Garchow
August 25, 2011 at 6:04 pmYou then export another XML that should open in RCX with files already relinked.
Is this timeline pretty basic? Like cuts only?
I have the pay version (2.5) so maybe there’s a difference in the functionality.
Jeremy
Jason Armstrong
August 25, 2011 at 6:07 pmSorry, I don’t mean to be dense (it just happens): I’m not really sure what I’m doing in this program. Conforming or importing? Ugh. Could you just hit me with a step by step after you have an FCP xml? Would be much appreciated.
Jason Armstrong
August 25, 2011 at 6:12 pmClipfinder. I have the timeline output to a FCP xml. Now I want to get it into redcine x but going direct is failing. What do I do with Clipfinder to help me out?
Jeremy Garchow
August 25, 2011 at 6:14 pmTools > Run Conform on FCP XML.
Choose your input XML.
Choose your output location/name XML.
Choose replace clips with R3D.
Choose a directory where your r3d files are.
Click Run Conform.
Jeremy
Jason Armstrong
August 25, 2011 at 6:21 pmSeemed to work, but Redcine X still crashed when I clicked ok after opening the xml file.
Re-installing to see if that fixes it.
Jason Armstrong
August 25, 2011 at 6:30 pmI thought so, but have found I left a couple of fades in and one layered clip. Simplifying. Will update shortly.
