Activity › Forums › Apple Final Cut Pro Legacy › FCP XML into Redcine X FAIL – Can anyone heIp me out?
Jeremy Garchow replied 15 years, 1 month ago 2 Members · 22 Replies
Jeremy Garchow
August 25, 2011 at 6:31 pmDissolves usually come in OK (and when I say OK I mean they are ignored in RCX), def needs to be one layer, and no effects.
Jason Armstrong
August 25, 2011 at 6:46 pmOk, that didn’t work. Is there an issue with the footage being spread over two drives? It links one drive fine and then when I manually connect another file and it goes on to relink it just shuts down.
I can open clips by browsing no problem, so Redcine X seems ok… Argh. This is frustrating.
Jeremy Garchow
August 25, 2011 at 6:48 pmWhat version of RCX? I guess the two drives could be a reason, but I’m not really sure on that.
Jeremy Garchow
August 25, 2011 at 6:55 pmSee if you can create two separate XMLs with the footage from separate drives in each XML.
Although, when using clipfinder, the footage is already linked. I think something else is amiss here.
Jeremy
Jason Armstrong
August 25, 2011 at 7:00 pmAfter linking the files in clipfinder, do I still use “open FCP xml” in RCX or is there another way of opening the new xml?
Jeremy Garchow
August 25, 2011 at 7:04 pmNo you have to import the XML. Try pointing to the directory on the second drive.
Jason Armstrong
August 25, 2011 at 7:18 pmNot sure. I inherited the editing job. However, I manually relinked EVERY file that looked for the second drive and it worked. I’d hate to see it go like that for the whole feature.
Once graded in RCX, what’s best to get it back into FCP for re-adding transitions and FX?
BTW, Thanks SO MUCH for hanging out here and helping me out. I REALLY appreciate it.
Jeremy Garchow
August 25, 2011 at 7:23 pmIf you import the XML in a timeline, then grade, then you can export the graded XML after render, or reconnect the graded files in FCP.
You should look in to FCP Reconnect, it makes things easier.
Or use Color do do a grade/conform.
Jeremy
