FCP X Transition and Keyframes
Hello everyone! Was wondering if someone can answer a couple questions for me.
1) When I put a clip in the primary timeline and a text in the one above it. if I apply a transition to the text, it affects both clips. How can I apply a transition to only the text?
2) I seem to have trouble with the keyframing system. The only keyframes I can get to stick are when I open the video animation and set the keyframe that way. If I simply click on the key frame + in the inspect, it doesn’t set correctly.
3) Is there a way to edit effects and text transitions? I can’t seem to edit or change the individual parts of the text animations.
Thank you so much!!!!!!!!!!!!!!!!!
